Old 12-27-2014, 04:22 PM   #1
ChevDog1
ChevDog1's Avatar
Best riding dropped shocks?
I now need shocks for my lowered c10. I have spindles and springs in the front and a rear flip. What are the best riding shocks for my application. Budget is always a concern.
ChevDog1 is offline   Reply With Quote
Old 12-27-2014, 07:05 PM   #2
SCOTI
SCOTI's Avatar
Re: Best riding dropped shocks?
Aftermarket 'drop' shocks seem to be very subjective as far as ride quality. You'll hear one guy say 'brand-X was great while another will say they were crap. The main issue is 'drop' shocks usually equal shocks w/less travel which impacts ride quality.
I always try to stick w/OE spec shocks unless using something developed for a certain drop by a company that R&D'd the length, stroke, & valving (Hotchkis, Ride Tech, etc...).
The alternative to shorter drop shocks is to build or buy an upper bracket for the front shocks & use OE length replacement shocks. Same for the rear.... relocate the lower brackets (shock extenders) and or make a new upper bracket to gain the most travel & best geometry possible.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 12-28-2014, 08:23 AM   #3
Hammered 77
Hammered 77's Avatar
Air Ride Techs Q Series. A little pricey but the best I've found since lowering my 77 C10 some 35 years ago. They come with a million mile warranty so they have done their home work on these shocks.
Hammered 77 is offline   Reply With Quote
Old 12-28-2014, 03:48 PM   #4
scottybaccus
scottybaccus's Avatar
If your shock mount and bump stop are not modified, you can keep stock shocks.
Scotty Baccus
scottybaccus is offline   Reply With Quote
Old 12-28-2014, 08:14 PM   #5
Jewbacca
Jewbacca's Avatar
I'm running front shocks on all four corners.
Jewbacca is offline   Reply With Quote
Old 12-28-2014, 11:46 PM   #6
midnight rambler
midnight rambler's Avatar
I just did my rear, it was bottoming out no c notch, i installed shock extenders with gabriel air shocks. Now the rear rides great. Next up is the front end.
midnight rambler is offline   Reply With Quote
Old 12-29-2014, 11:44 AM   #7
ChevDog1
ChevDog1's Avatar
How does it ride? What springs are you running in the rear?
Old 12-30-2014, 10:55 PM   #8
Jewbacca
Jewbacca's Avatar
Not that great. Need a little bit longer ones in the rear.
