Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 12-28-2014, 12:03 AM   #1
88Ironduke
Center Speaker Options
My truck has no bracket or even a point to mount a stock speaker set up in the center dash. So, with out reinventing the wheel what are the rest of the truck owners doing to mount a pair of 3.5" speakers in the front dash?
Thanks in advance.
Paul
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 12-30-2014, 09:34 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Center Speaker Options
Skip it and go with kickpanels/console/etc. No 3.5" will sound that great, especially mounted in the dash (you'll barely hear anything but *twang* on the road)/.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-04-2015, 02:55 PM   #3
88Ironduke
Thanks. That's what I was thinking. I'm going to use a infinity component set. Hopefully my truck won't acoustically impaired too badly.
88Ironduke
Old 01-05-2015, 02:08 AM   #4
Matador
My 1987 has Infinity speakers in the doors. They were there when we bought it in 1996. They work great!
I also had a truck with a bookcase speaker that I set on the transmission tunnel. That actually produced great sound, but since it was "shooting" the sound up, where your head was really made a difference in volume. But, being broke at the time, it worked just fine.
But, I later switched to door speakers. The sound is much more even.
Matador is offline   Reply With Quote
Old 01-09-2015, 03:04 PM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: Center Speaker Options
I used some 4" speakers. 2 of them and made my own holder for them. And yes you can hear them very well! They made a hugh differance in the quality of the sound system in my 71. I tweeked the metal so it would stay in place and then added a peice of black foam around the top of it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-11-2015, 06:24 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
I used two later year (4x6) speakers wire tied below the dash in my 79
sounds better then stock (AM mono)
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-27-2015, 07:29 PM   #7
RetroMfgWil
If you guys aren't familiar with Dual Voice Coil speakers, we have DVC dash replacement speakers for this particular application. The Dual Voice coil allows a stereo output sound from one center speaker.
You can look up your year make and model and should give your choices on our site.
www.retrosound.com
RetroSound...Modern Sound for your classic
RetroMfgWil is offline   Reply With Quote
Old 03-06-2015, 11:51 AM   #8
88Ironduke
I like the DVC center speaker option. While I have no problem engineering a solution I don't care to do so while decent options exist. A good center speaker that will provide both left and right channels is nice option. Once funds appear I will order the speaker and kick panels to go with it. Add an 8" powered sub under the bench seat and I should have a decent sounding ride.
Paul
