Old 12-28-2014, 11:55 AM   #1
canadian 4x4
canadian 4x4's Avatar
Hydraulic throw out bearing in A833od
I'm looking to install a hydraulic throw out bearing on my A833od. Currently the truck has a hydraulic slave cylinder set up,but the truck is z'd and body dropped and I have no room to get exhaust through with the current setup. Can anyone give me some pointers on the conversion? I searched the forum but there isn't a lot of info on A833od
85 swb c10 6/6 drop
83 c10 bagged and sfbd project
canadian 4x4 is offline   Reply With Quote
Old 12-28-2014, 01:18 PM   #2
v30crewcab
v30crewcab's Avatar
Re: Hydraulic throw out bearing in A833od
it uses a stock chevy bellhousing and thowout, so I'd say one that will work with a regular chevy trans should work.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 01-01-2015, 10:43 AM   #3
canadian 4x4
Thank you, I grabbed one from a nv3500 hopefully that does the trick
85 swb c10 6/6 drop
