Old 12-28-2014, 02:33 PM   #1
j.kirn
K Model Frames
does anyone know the differences in the frames from 60-66
j.kirn is offline   Reply With Quote
Old 12-28-2014, 04:35 PM   #2
padresag
Re: K Model Frames
in which way Joe?
ron
padresag is offline   Reply With Quote
Old 12-28-2014, 04:37 PM   #3
padresag
Re: K Model Frames
http://67-72chevytrucks.com/vboard/s...d.php?t=550856
frame measures
ron
Old 12-28-2014, 06:01 PM   #4
j.kirn
Re: K Model Frames
frame widths
Old 12-28-2014, 06:05 PM   #5
j.kirn
Re: K Model Frames
I thought maybe they were the same width for all years but I c they were not, just as the 2wd 60-62 were wider than the 63-66
Old 12-28-2014, 06:20 PM   #6
padresag
Re: K Model Frames
I believe that they are pretty close until you get to the back end. the 60-62 have that extension that goes outward.there are some diagrams on here a while back
they were both ladder frames
ron
Old 12-28-2014, 07:03 PM   #7
padresag
Re: K Model Frames
http://67-72chevytrucks.com/vboard/s...d.php?t=325736. this was the link that I was thinking about. on page one there is a picture of a 4 x 4 frame but it is mislabeled as a 63-66 when it is a 60-62 frame and it is the tubular frt cmember(which was also the eng mount) and the outboard rear extensions which signify the early rails. I think if you ran the rails straight back from where you get those extensions mounted; you would get 34" width at the rear. the cab mounting frame brackets are longer on the earlier frame than the 63 and up frames
what are you trying to find?
ron
Old 12-28-2014, 07:10 PM   #8
j.kirn
Re: K Model Frames
all of my frames are 60-62 ks , bed cross sills from 2wd 63-66 work on these without modify them?
Old 12-28-2014, 07:32 PM   #9
padresag
Re: K Model Frames
do the sills mount right on to of the frame rails or onto brackets on the side of the rails on your 60-62 frames. the 63-66 mounted right on top of the frame rails
ron
Old 12-28-2014, 08:01 PM   #10
padresag
Re: K Model Frames
Joe; I went back and looked at this picture(just took this one) to clarify a few things for myself. those extensions are for a suburban 4 x 4(n/a here ), but it does show p/u box brackets
ron
Old 12-28-2014, 08:58 PM   #11
j.kirn
Re: K Model Frames
thanks for the help ron, yes the sills bolt to perches on side of frame. I will have to drive to get the sills to c just what I need. this is for my 62 k20
Old 12-30-2014, 03:33 PM   #12
61K10
61K10's Avatar
Re: K Model Frames
you probably know this but here's another pic out of my 1960 book . says the k14/25 is the same as the c30/40 and p-20/30
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
