Old 12-28-2014, 04:18 PM   #1
Pizzalovr36
Using an inline 6 bell housing on a v8
So I'm using a Saginaw 4 speed on a inline 6 bell housing ! The problem is the front bearing retainer is a different size on the factory three speed than 4 speed! And leave some play cause the 4 speed is smaller! Any ideas!
Pizzalovr36 is offline   Reply With Quote
Old 12-28-2014, 04:26 PM   #2
tcrist
Re: Using an inline 6 bell housing on a v8
How much smaller? 1/16, 1/8 or more.
If it is fairly small you can just roll up a thin piece of sheet metal and tack or in some other way "bond" the ring onto the bell housing. If it is too much you might have to have a ring machined and then "BOND" it to the bell housing in some fashion.
Terry
Soon to be retired and moving to Bristol, TN.
tcrist is offline   Reply With Quote
Old 12-28-2014, 06:11 PM   #3
geezer#99
geezer#99's Avatar
You can buy spacers like this example.
http://www.summitracing.com/int/part...6041/overview/
Old 12-28-2014, 06:17 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
If I am understanding you right you need one of these....
http://www.dennymac.com/muncie-bell-...g-adapter-ring
Cheapest I found. There is also some other good info there.
LockDoc
Leon
Old 12-28-2014, 07:27 PM   #5
Lattimer
Lattimer's Avatar
What Lockdoc said.
Unless you have a truck 3-speed you can rob the input bearing retainer from, because they interchange and the 3-speed will be the larger diameter. I did that when I put the 4-speed in my truck initially.
For my TREMEC I used an adapter like LockDoc posted, only I just took measurements from a thread on here and had a local machine shop make it for me.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 12-29-2014, 09:04 AM   #6
Pizzalovr36
I tried swapping the input shaft retainer with the Saginaw three speed and 4 speed but they won't work their two different bolt patterns
Old 12-29-2014, 10:37 AM   #7
MARKDTN
Why not just get the correct bellhousing? Should be able to find at any swap meet.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-29-2014, 10:54 AM   #8
Lattimer
Lattimer's Avatar
Really? Mine were a direct swap.
Shawn
Old 12-29-2014, 11:04 AM   #9
factorystock
factorystock's Avatar
I believe you need the '63-'67 bellhousing for the small retainer trans, '68-'72 bellhousing for the larger retainer trans.
factorystock is offline   Reply With Quote
Old 12-29-2014, 11:07 AM   #10
geezer#99
geezer#99's Avatar
Maybe he doesn't have a saginaw 3 speed Lattimer!
Could be a muncie!
Old 12-29-2014, 11:18 AM   #11
Lattimer
Lattimer's Avatar
Could be a muncie!
Didn't think about that....
Shawn
