Old 12-28-2014, 07:17 PM   #1
pwdcougar
pwdcougar's Avatar
97 Rear Bumper
Need to finally replace the rusted through rear bumper on my 97 pickup. Looking through Ebay right now. Question:
Are the fleetside rear bumpers all the same? I found a bumper in my price range but it says that it will fit a Suburban but not a C/K Fleetside truck. Other listed (and more expensive) bumpers say they fit Suburbans Tahoes and C/K trucks.
What gives? I thought that they all had the same bumpers.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 12-28-2014, 07:32 PM   #2
pwdcougar
pwdcougar's Avatar
Re: 97 Rear Bumper
Or to put it another way, some listings show the same bumper for 97 Suburbans and fleetside trucks and others dont. Do the suburbans have the same bumper as a pickup?
Paul
Old 12-31-2014, 04:52 PM   #3
owned many chevys
Re: 97 Rear Bumper
Lol just went thru this with one of my trucks suburban and Tahoe same pickups fleetside will not work on step bed they will bolt up to frame but curved part of a factory bumper under tailgate step is short fleet is wider if you can understand my explanation
owned many chevys is offline   Reply With Quote
Old 12-31-2014, 08:32 PM   #4
YankeeHauler
YankeeHauler's Avatar
Re: 97 Rear Bumper
Good to know, gonna be in the market for the same ('97 fleet) myself, thanks!
"The problem with quotes on the Internet is that it is hard to verify their authenticity."
Abraham Lincoln
YankeeHauler is offline   Reply With Quote
Old 12-31-2014, 09:57 PM   #5
pwdcougar
pwdcougar's Avatar
Re: 97 Rear Bumper
Not sure I understand the whole explanation but the upshot is the Suburban/Tahoe bumper is different from the fleetside pickup bumper.
Thanks for the info!
Paul
Old 01-01-2015, 12:04 PM   #6
1badgmc
1badgmc's Avatar
Re: 97 Rear Bumper
Imagine you're stepping up onto one of these bumpers. Your foot is on the step pad. In front of your toes, at the back of the step, is a lip that curls up. It acts as sort of a filler panel for the gap below the tailgate. On a fleetside bumper, that lip goes along the majority of the back of the bumper. On a sportside bed, that lip is considerably shorter due to the narrower bed.
You could use a sportside bumper on a fleetside/SUV, but it would look really goofy with that lip being so short. You wouldn't be able to put the fleetside bumper on a sportside at all, though.
Old 01-01-2015, 01:01 PM   #7
pwdcougar
pwdcougar's Avatar
Re: 97 Rear Bumper
I get that the fleetside and sportside bumpers are different because of the truck width. Is it the lip below the tailgate that is different on the Sub/Tahoe bumpers then?
A friend made the sportside/fleetside mistake with an 03. The bumper bolted right up but it looked goofy being so narrow.
Paul.
Old 01-01-2015, 03:38 PM   #8
JJR
JJR's Avatar
Re: 97 Rear Bumper
The bumper off the Suburban will work on your fleetside but you will need to use the brackets from your truck. The Suburban bumper brackets/mounts are different. If you look at the LMC website, you will see the same part number listed for both the Suburban and Fleetside rear bumper.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 01-01-2015, 05:21 PM   #9
pwdcougar
pwdcougar's Avatar
Re: 97 Rear Bumper
Thanks!
Paul
Old 01-02-2015, 07:06 PM   #10
UKNOWME
UKNOWME's Avatar
Re: 97 Rear Bumper
Where was JJR on 12-28-14 at 4:19? Could've saved a lot on confusion.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 01-02-2015, 07:15 PM   #11
pwdcougar
pwdcougar's Avatar
Re: 97 Rear Bumper
Yeah. Somehow fleet vs style got thrown into the mix.
Paul
Old 01-03-2015, 12:26 AM   #12
JJR
JJR's Avatar
Re: 97 Rear Bumper
Sorry guys, I have not been visiting as often as I should. I had to go through this on my 93 GMC. Got it off EBay in 2002 from the original owner who was in Mississippi. Didn't think to ask where he lived before that. Turns out it was Ohio and the winters took its toll on the rear bumper, the brake lines and the fuel lines. The rear bumper looked fine from the outside but you could pull big pieces off the backside. I ended up getting a new bumper off EBay and got the replacement mounting brackets at the local pull-a-part. Hopefully pwdcougar's brackets can be re-used.
