12-28-2014, 09:22 PM | #1 |
Rear End widths
Can anyone tell me if A 1995 c1500 rear diff will bolt into my 81 C10? If not what are the differences?
Thanks Willie |
12-28-2014, 10:41 PM | #2 |
Re: Rear End widths
Bolt in, probably not. At the very least the perches will be in a different spot. I think they are wider than 73-87 rears also.
12-29-2014, 09:34 AM | #3 |
Re: Rear End widths
The only thing they have in common is the diff internals. Wider and the perches are in the wrong spot.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
12-29-2014, 05:46 PM | #4 |
Re: Rear End widths
Sounds like my luck. Found a deal on a 5 lug 3.73 posi. Oh well.
12-29-2014, 06:02 PM | #5 |
Re: Rear End widths
12-29-2014, 06:27 PM | #6 |
Re: Rear End widths
Shock mounts would also have to be re-located.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
02-18-2015, 12:20 PM | #7 |
Still plays with trucks
Re: Rear End widths
It is actually a popular swap into a square body as it places the rear wheels further out and closer to in line with the track width of the front.
Leaf perches are in the completely wrong place so they need removed and new ones installed in the correct place for your truck. I can't remember the increase off the top of my head but it was a little over 1" per side. The only internals it shares with the older 10-bolt is the ring gear. It uses 30-spline axles instead of 28-spline like the square body version so the carrier is also different. As strong as the truck 12-bolt with many more donors on the road to choose from.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
02-19-2015, 02:56 AM | #8 |
Re: Rear End widths
I was thinking about this diff as well but for a square 1 ton crew that im swapping 1/2ton stuff into. Was thinking the shock mount location may work with the 1 ton frame. Has anyone tried this?
86 Burb, 5/7 drop, 18" rims, big stereo, work in progress, as well as daily driver. 86 Short box just starting the build. 86 GMC 1500 2wd, ugly blue farm looking truck with a mild 454... More to come! 98 Cheyenne Ext cab short box 2wd. Driver and maybe future project. |
