Old 12-29-2014, 03:34 PM   #1
savatreatabvr
savatreatabvr's Avatar
Signs of a Collapsed Lifter or Burnt Valve?
In my previous threads I explained again the condition of my mid '70's Chevy c20 454 and got great advise. This time I decided to hook up my vacuum gauge to see what it said. I'm leaning towards it being a burnt valve because the vacuum needle isn't perfectly steady and the lifters aren't making noise, am I right?
savatreatabvr is offline   Reply With Quote
Old 12-29-2014, 10:01 PM   #2
Mv7fd
Re: Signs of a Collapsed Lifter or Burnt Valve?
To check for a bad lifter either cut the tops out or remove the valve cover and make sure all your rockers are moving properly that's how I found out that I had a bad lifter then found out I had a rounded can lobe
Mv7fd is offline   Reply With Quote
Old 12-30-2014, 11:03 AM   #3
Bigstevex4
Bigstevex4's Avatar
Do a leak down test check valves. or compression if bad enough.
Bigstevex4 is offline   Reply With Quote
