Old 08-20-2003, 09:28 PM   #1
mhorning
mhorning's Avatar
4wd question
Well I've actually driven my truck for the past four days- a record so far. I think I am starting to get the kinks out of it. I have noticed a new problem that I really haven't checked into yet, but i thought I would see in anyone else in the group has seen something similar. The truck seems to pop out of 4wd after I engage it. The manual says that this may indicate that the transfer case is worn. The truck does have automatic locking hubs. I've heard these can also be a problem. Anyone have any thoughts? Thanks.
Mike H
mhorning is offline   Reply With Quote
Old 08-20-2003, 10:56 PM   #2
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
got a little more info on the truck? year, 10/20/30 engine trans transfer case axles etc
mike
mike reeh is offline   Reply With Quote
Old 08-20-2003, 11:32 PM   #3
mhorning
mhorning's Avatar
The truck is an 86 k10 1/2 ton. It has a 350 in it with a 700 R Transmission. I am not sure about the transfer case and axles. What's the best way to find that out?
Old 08-21-2003, 06:55 AM   #4
85 K5
Look on the transfer case you'll find a round metal sign that will probably say NP208. Also on the lid of the glove box you will find a sticker that has the axle ratios.
350 Crate 10 bolt 3.73 2.5 lift 32x11.50 1904 Edelbrock
http://www.oplnk.net/~spirit/K5front.jpg
85 K5 is offline   Reply With Quote
Old 08-22-2003, 08:51 AM   #5
mhorning
mhorning's Avatar
MIke the transfer case says 208C2 and the rear axle is 3.08.
