Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 12-29-2014, 06:50 PM   #1
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Lincoln 140T vs. 140C
After shopping around I've found three different options when looking for a new welder. I have taken the Miller off the list due to the higher cost. All three have 20% duty cycle at 90 amps, and similar warranties.
Hobart 140 - I know is a economical version of the miller. It has variable wire feed and five position tapped voltage control. It is the cheapest at $500.
Lincoln 140T - Same options as the Hobart 140. It has variable wire feed and five position tapped voltage control. Little bit more expensive, seen it listed for around $540. Paying for the Lincoln name?
Lincoln 140C - It has variable wire feed and variable voltage control. I swung by the local welding store and there is a $75 rebate on this model and is currently listed for $659 after rebate.
My question. The Lincoln 140C costs $159 more than the Hobart, and $119 more than the 140T. Is the variable voltage control paying the extra cost, or should I just go with the Hobart.
Thanks,
Wes
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
