Old 12-30-2014, 01:10 AM   #1
chevyfox
4 inch lift with 35s?
Can you run a 4 inch lift on 35s with out any trimming I have an 87 k 10 but I have friends who say it wont work
chevyfox is offline   Reply With Quote
Old 12-30-2014, 01:32 AM   #2
74CustomK20
74CustomK20's Avatar
Re: 4 inch lift with 35s?
I had a 4" lift, 35 x 12.50 master craft coursers on 15x7 wheels. Fit fine and even when bound up never rubbed. This will all depend solely on your wheel choice. That is the make or break "x factor"
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 12-30-2014, 10:36 AM   #3
cadillac_al
I used to run 35's with a 2" lift and some trimming. I don't know if another 2" would avoid the trimming or not but fenders are dirt cheap so it is somewhat reversable. I had 35x12.50's on 8" rims. When I first got the tires I bought 7" rims but I couldn't get the tread to lay flat on the ground and didn't want to wear out the middle of the tread so I bought 8" wheels. I don't like any 12.50 tire on a 7" rim.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 12-30-2014, 10:50 AM   #4
Bigstevex4
Bigstevex4's Avatar
got a 90 jimmy 4 inch 36 1050s no problem
Bigstevex4 is offline   Reply With Quote
Old 12-30-2014, 11:03 AM   #5
slotard
If you're looking for a truck that works well rather than just hard parking, a little lower ride height makes for much better handling and trimming isn't hard.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 12-30-2014, 12:12 PM   #6
lowrodderchev
lowrodderchev's Avatar
I'm running a 4 inch lift on my 75 blazer 35 inch tires no clearance issues
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 12-30-2014, 12:59 PM   #7
Duvall
I run 35-12.50-15's BFG Mud Terrains on factory rally wheels with a 4 inch lift. No problems, no trimming.
I tried to post pict but can't for some reason. It took me a bit to get use to the look but wouldn't change now.
Todd
Duvall is offline   Reply With Quote
Old 12-30-2014, 07:25 PM   #8
chevyfox
I really just want it for the handling plus I think I'll look way better I'm sick of my 6 inch lift with rear blocks
Old 12-30-2014, 09:49 PM   #9
Kinze
Buddy has a 2 1/2in. lift and running 36in. Hummer tires, no rubbing.
35's with a 4in. lift has been done a million times.
Kinze is offline   Reply With Quote
