Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 12-30-2014, 01:17 AM   #1
1960chevypanel
Suburban vs pickup frames?
I understand that 60-63 Suburbans and panels have rear frame horns (where the pickups obviously don't). Are there any other differences in the design, mounting point locations, or anything else? If I snip the rear horns off will it instantly become a pickup frame?
1960chevypanel is offline   Reply With Quote
Old 12-30-2014, 02:40 AM   #2
argonaut
argonaut's Avatar
Re: Suburban vs pickup frames?
This is true for the 63-66 frames. Not sure if early frames were any different. Carryalls also have an additional pair of body mount brackets, but they are simply riveted on.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 12-30-2014, 03:20 AM   #3
1960chevypanel
60-62 Burbs and Panels have frame extensions at the rear that are riveted on. Once you remove those the frame is the same as a shortbed pickup. 63-66 look like the frame would need to be measured and shortened.
Old 12-30-2014, 03:58 AM   #4
padresag
here is an example of a 60-62 suburban or panel 4 x 4 frame and rear extensions, the 4 x 4 is a ladder type frame and goes back fairly straight until it comes to the extension. the extension allows the frame to go out to 42" from 34". the 2 wheel dr 60-62 has an xmember and the frame tapers out from the trans area to the rear which on a suburban 2 wheel is 42". it has an extension also. they are both riveted on. the 63-66 suburbans and panels also have a riveted extension which removed would be equivalent to a swb p/u frame.
ron
padresag is offline   Reply With Quote
Old 12-30-2014, 07:35 PM   #5
66 Burban
66 Burban's Avatar
ron
My 66 Suburban frame is straight and does not have a riveted extension. Frame rails are one piece.
Remember: "When seconds count, the Police are only minutes away".
Thx,
Billy B.
66 Burban is offline   Reply With Quote
Old 12-30-2014, 09:13 PM   #6
padresag
here is my 64 frame and just behind the rear spring hanger and that rear c/member you will see a bolt head on the top of the frame; that is where you will see the pieces meet
ron
Old 12-30-2014, 10:23 PM   #7
padresag
yours is a chevy 2 wheel dr as is the one in this picture
ron
Old 12-30-2014, 11:11 PM   #8
1960chevypanel
So the answer is that 63-66 2WD's had one piece frame rails (no extensions). I checked a 63 Panel and a 65 Suburban today and found the same thing. Has anyone cut these down to make a shortbed pickup frame? I'm wondering if I have to do anything besides cut off the rear frame horns.
Old 12-31-2014, 05:06 AM   #9
padresag
yes chevrolets but I cannot say about GMCs. perhaps this all has to do in that area when there is a rear spring hanger mounted there. if someone has a 63 - 64 2 wheel dr panel or suburban pls check
ron
Old 12-31-2014, 12:34 PM   #10
1960chevypanel
I checked a '63 Chevy panel and a '65 GMC Suburban and they're both one piece. So no difference between Chevy and GMC. So it sounds like 60-62 2WD use an extension, as do 60-66 4WD, but 63-66 2WD are one piece.
