Old 12-30-2014, 10:16 AM   #1
scotts72
scotts72's Avatar
Transmission question
Hey guys have a question and looking for a solution. I have gotten my 68 driving but have found down here in Texas the stock 350 trans is not a good match, when you get on the road here you have to run 70 or 80 or you will get run over, at these speeds I am turning high rpms and the truck is screaming. I wanted to see if you all just deal with it or have changed the trans to something newer. Thanks for letting me pick your brains.
scotts72 is offline   Reply With Quote
Old 12-30-2014, 12:10 PM   #2
Eddie H.
Eddie H.'s Avatar
Re: Transmission question
Your choices are either going to an overdrive trans like a 700R4 (which is a pretty easy swap), or higher rear end gear ratio.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 12-30-2014, 12:49 PM   #3
mbradsher
700R4 is a good swap not too hard to do. Just did it on my 72. still playing with the torque converter lock-up. Haven't found one that I like yet.
mbradsher is offline   Reply With Quote
Old 12-30-2014, 01:02 PM   #4
Lee H
Lee H's Avatar
That's a nice looking truck! I'm living with my 350THM until it goes out, then swapping to a 700R4. At 70 MPH I'm taching right at 3500.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-30-2014, 01:19 PM   #5
kwmech
What rear axle ratio you running?
Old 12-30-2014, 01:54 PM   #6
scotts72
scotts72's Avatar
I want to say the ratio is a 3.73 but I would need to check for sure. I wanted to ask because I am running into the trans leaking after sitting for awhile which is normal for older trans that hasn't been rebuilt. I just wanted to see before jumping into what was needed to do a conversion. My wheels and tires I guess are on the side burner for now. LOL
Old 12-30-2014, 02:08 PM   #7
leftybass209
leftybass209's Avatar
As stated, you have 2 options, overdrive trans or freeway flier rear gears. I have a 700r4 and love it. However, a 2004r and a 4l60, are also great overdrive choices with the 2004r having slightly more desirable gear ratios. The catch: if you do NOT have 3.42 gears or higher, your truck won't be in any hurry to accelerate off the line. I have 3.08 gears and it will move easily, don't get me wrong, it just feels underpowered. It also spins the gears at a real low rpm in overdrive.
leftybass209 is offline   Reply With Quote
Old 12-30-2014, 02:26 PM   #8
diceman50
The 7004R is certainly a good transmission, but the first gear ratio is so low that it is almost useless unless you are hauling and/or towing heavy loads. The 200-4R has a better first gear for cruising in my opinion. (2.74 vs. 3.06) And it has the same .75 O.D. as the 7004R. Plus it is a close ratio transmission compared to the 700. Some might try to tell you that they aren't as strong as the 700 but I have seen them behind 600 horsepower Buick Grand Nationals with no problems. I have had both in my "Cruisers" and prefer the 200-4R. I recommend that you check them out before you make a decision.
Great looking truck!
"In an insane world a sane man must appear insane" ~Spock~
diceman50 is offline   Reply With Quote
Old 12-30-2014, 04:26 PM   #9
cdowns
cdowns's Avatar
Those 200 trannys livin behind 600 hp grand nationals are $2500-$3000 setups not junkyard or local yokal places
Old 12-30-2014, 04:51 PM   #10
diceman50
Just an example. I don't think he needs one at that level and it has been my experience that you can build an equal quality transmission for about the same money. If your using junkyard stuff then use what you can find.
Old 12-30-2014, 05:21 PM   #11
Andy4639
Old member
Andy4639's Avatar
Talking Re: Transmission question
Since no one has mentioned it:
Gear vendor is another choice.
https://www.gearvendors.com/
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-30-2014, 05:52 PM   #12
Z10
Z10's Avatar
I just made this swap earlier this year. Running a 700r4 from a 91 Corvette, 2400 rpm stall, 3:73 rear, and 30" tall tires. The engine is turning about 2000 RPM at 70mph.
I think you'll love the first gear, it will scoot off the line.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 12-30-2014, 06:26 PM   #13
mechanicalman
What part do you not like, the vacuum cut-out switch? Are you using a relay?
mechanicalman is offline   Reply With Quote
Old 12-30-2014, 09:09 PM   #14
outdoorsman310
outdoorsman310's Avatar
What size tires do you have? I have 265/75/16, I think they are 31". My rear is a 4.57 and i have a 350/350 it ran at 28/3500 on the highway. It removes carbon and you always have passing power!
A 700r4 would be a good option if you want overdrive. Make sure the kickdown cable is adjusted properly as it is very important.
outdoorsman310 is offline   Reply With Quote
Old 12-31-2014, 05:03 PM   #15
Tkmadone
I just swapped a 2004r in for my TH400 and I love it. I have 3.54 gears and I now turn 2000 rpm at 70. I wired it up to lock the overdrive in 4th, which cost about $15 to do.
Tkmadone is offline   Reply With Quote
Old 12-31-2014, 05:47 PM   #16
Fitz
Try an overdrive transmission like the 2004R or 700R4. I use a built turbo 400 backed by a Gear Vendors overdrive which gives about the same final drive ratio as the 700R4 but will take the torque of my big block which the 700R4 will not.
Fitz is offline   Reply With Quote
