Old 12-30-2014, 10:04 PM   #1
mlbrickey
seat question
Would it take much modification on a 82 GMC bench seat to make it work with my 70 brackets? The PO had rigged up the bench I have now with the real brackets. Its not very safe and need to find a solution. I found a 82 GMC with its bench at a parts yard. Any info is appreciated.
mlbrickey is offline   Reply With Quote
Old 12-30-2014, 10:16 PM   #2
hugger6933
Re: seat question
I think it would be one of the easiest things you could do as far as mods for your truck, unless you break bolts so use some penetrating oil.
hugger6933 is offline   Reply With Quote
Old 12-31-2014, 09:01 PM   #3
Pondscum
Re: seat question
All I had to do when I did this in a k20 was remove the swap the sliding mechanisms. Now it did go from worm out 72 bench to 79 bench and all I had to do was drill some holes. The only thing I didn't like was the new seat made me sit higher in the cab and caused headroom issues for me although no one else noticed.
Pondscum is offline   Reply With Quote
