Active Member
![]() Join Date: May 2013
Door gap at windshield frame issue
So I bought my first Blazer. Had a 70 pickup back in the day. I got a 72 blazer from Arizona so I bought it just from pictures. It has doors from a pickup that were cut down for the top but the gap between the windshield frame and the vent windows on both gets wider towards the top. The top fits great so I dont think the windshield frame is bent forward. I don't want to buy new doors till I know what the issue is. Has anyone seen this before? Could it be the wrong year doors? Any help would be appreciated.
![]() Join Date: Oct 2006
Re: Door gap at windshield frame issue
How's the door gap at the B pillar and rocker? I doubt it's the door itself.
You will probably need to shim either the body mount at the A pillar or B pillar to correct this. If the door fits correctly at the B pillar, then the cowl is angled too far forward and the body mounts are the issue. |
Active Member
Thanks. I didn't think about the body mounts. They do need to be replaced but the rest of the door gaps are goor and the top fists right. I know it wouldn't taks much to fix that gap but do you think the top will still fit right after angling the firewall back?
Carpe manana
![]() ![]() Join Date: Dec 2010
Welcome from Montana! Are the rocker boxes in place? Would be great to see more pics of your K5 when poss. Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Active Member
I will look at the boxes tomorrow. Here is a pic of it. I have a single wall top for it because the one in the picture is a double but the blazer is set up for the single. It needs more work than I thought but there is no rust in the body so it's a good start.
Active Member
Here is another
Carpe manana
Looks great! One day I'd like to have a 2wd K5.
2WD Jimmy
![]() Join Date: Mar 2005
I am going to guess that the door was replaced during a repaint. A good body man can fix it. Welcome to the world of convertibles. lol
Take out the wing window assembly and bend the door frame to match the windshield post. Then re-install the wing window.
Don aka Rocket_Man 72 K5 Blazer 454 CI 2002 Honda VTX 1800C |
Interesting suggestion. But I think you might run into problems with making the window glass channel too loose at the top and too tight at the bottom by pivoting the front glass channel like that. But I've never done this, so who know, it might be the ticket.
Active Member
I am going to try the body mounts first. They do need to be replaced and with the wide gap at the back of the door and other issues this sounds the most correct way to resolve this. But still open for other options just in case this doesn't work. I will keep you all posted.
#12 | ||
I just finished doing my entire body restoration which included reassemble of the doors and glasses. I have about 20 years of experience as an auto body tech. but, I could be wrong. Don't over think these older rigs, they were not rocket science like today's cars.
#13 |
Active Member
This is staying a running and driving project and will not be a full restoration. I tried that with my 70 pickup years ago and it never went back together. I do want to pick the color and cut to door jams and firewall etc in then put it back together till I do the full paint job.
#14 | |
You can move the doors in and out but to move forward or back you have to pull the fenders. From what I can see, you have about as good of gaps as this car has ever had and if you want them perfect you better plan on doing some custom fitting of the hinges and especially the cowl plenum panel where it meets the upper door. I promise you, these things were not perfect from the factory. I was a body repair man back in those days. I still think you're going to find that window frame bent a little. So, like I said, if you pull the vent window assy out, straighten the door frame to match the pillar and put it back, tightening the vent screws from the top at the door frame and work your way down, you'll solve the problem in your original post. The larger gap at the rear of the door is perhaps a good thing, when you remove the top it will have a tendency to close that gap a bit. These older cars and trucks had terrible gaps from the factory. Today's cars, you could measure the gaps with a micrometer and find them pretty darn close. Not so in days of old. Good luck with your project.
#15 |
Active Member
I agree but I know the body mounts are shot so that's why I am starting there then I can fine tune it from there. But right now the the gap the way it is at the vent window it doesn't even touch the rubber.
#16 | |
I did my body mounts and it worked out fine but, I had to re-adjust everything when I was done. Just to give you a heads up, make sure you get the body straight on the frame, side to side, before tightening the body mounts. Otherwise you'll have a tough of a time aligning the hood and the entire front sheet metal group. Also, you can buy new carriage bolts for the swap at any good hardware store for a lot less than you can get them from the usual auto parts suppliers. The rear for the bed portion are pretty standard 5/16 bolts in 6" to 12" lengths and everything in between. They can be bought in any length you want and then you can cut off to the size you need or you can cut the tailings off with a sawzall after the install. Most of them are easy to get to. You are going to encounter some that are rusted so bad that you have no choice but to replace them. You have to grind away the tack welds on them to get them out of the bed. The front ones (seats forward) are larger and can possibly be re-used, and I would if possible. I did put new bolts in the very front radiator support because they were not welded and easy to get to.
#17 |
![]() Join Date: Jan 2013
Fact assem. Manual
#18 |
Active Member
What Manual is that. Is it in the regular 1972 manual? Or is there one just for the blazer?
#19 |
Factory assembly manual,very informative, no table of content or index so it's a process of searching to find things, it is our truck " bible"
#20 |
Active Member
Cool. I have one for my 70 I had. I just need to get one for a 72.
#21 |
Pretty cool doo142. My door gaps suck as well. But I'll live with them. Mine is in No way as prestige as some of yours. I've beat the hell outa mine over the years. And it was before I got it as well. It'll never be fully restored but I make it look ok for Sunday cruises.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
#22 |
in the first picture it looks like your vent window is sagging into the door...maybe another pic needed?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
#23 | |
![]() Join Date: Oct 2001
jmo
Things happen for a reason! |
#24 |
![]() Join Date: Apr 2007
