12-31-2014, 12:04 AM | #1 |
copper oil pressure line
hey guys, going back with copper oil line for oil pressure gauge/ just need a couple pics as the best way you ran your lines and how you did it in case you had to repair your line. i.e. coiling of line, thanks in advance for the replys
12-31-2014, 12:39 AM | #2 |
Moderator
Re: copper oil pressure line
I ran mine out of the factory firewall grommet right above the distributor. The wire then coils down toward the engine and then screws into the block. member LocDock sells a new replacement if you are needing to repair yours.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 12-31-2014 at 12:49 AM. |
12-31-2014, 01:52 AM | #3 |
The Older Generation
Thanks Richard. Here is a thread I posted with the measurements and bending instructions for the line too... http://67-72chevytrucks.com/vboard/s...d.php?t=613238 LockDoc
12-31-2014, 12:29 PM | #4 |
thanks guys my old one when i got the truck was mangled so i replaced it with plastic tube with vacuum hose around it, now that one is leaking so i decided to go back with copper, thanks again and lockdoc by the way the diagram is great
12-31-2014, 12:35 PM | #5 | |
No problem, post back if you have any questions.... LockDoc
12-31-2014, 12:44 PM | #6 | |
when i ran my oil line i slid a rubber vac hose over the whole length of the copper tube just too help protect it from damage.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
12-31-2014, 01:56 PM | #7 | |
Thanks, I have seen a few of the lines with the hose on them. I think I have a couple in my parts stash that I removed from trucks over at the salvage yard. LockDoc
12-31-2014, 02:08 PM | #8 | |
I should've used a union for ease of engine removal. perhaps i'll ad it at a later date. one cant deny the one peice soild line though. I wont use the plastic stuff anymore...its just cheap
12-31-2014, 02:39 PM | #9 |
This is a pic that I found on this site a couple of years ago. It allegedly is original oil pressure tubing that was being offered for sale on the Parts Board. I used it as a model when I repiped my oil pressure tubing.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
12-31-2014, 03:04 PM | #10 |
Mine looks mostly like the one right above, but mine's a big block so it's in a different spot. I wonder if that's what the connector is for in the middle... universal on the one side and engine-specific on the other perhaps?
Either way, I always wondered about the union and am glad to see it's normal.
12-31-2014, 05:05 PM | #11 | |
Yes, the connector in the middle is the union. The union uses the compression sleeve nuts, the same as both ends of the line. LockDoc
