Old 12-31-2014, 12:05 AM   #1
72Blazerod
72Blazerod's Avatar
How much can a 1981 1 ton 3+3 4x4 tow?
Hi Guys,
I'm looking at a 1981 K30 3+3 4x4 and I want to know if it will pull my trailer. My trailer is a 29' 2004 Jayco Jayflight with a slide. It weighs about 6000 lbs, dry. The 1981 Chevy is a one ton with a 454 and a turbo 400. I also live in the mountains, anywhere I want to go, I'll have have to take it up some steep grades. I love the look of the old "boxy" Chevs (I used to have a '79 GMS Suburban and I miss it). What do you guys think?
1987 GMC Suburban 1/2 ton 4x4 (Beater)
1998 GMC Suburban 2500 4x4
1972 Olds 442 Convertible
2006 GMC 2500 Duramax Crew Cab (Sold)
1972 Blazer 4x4 (Sold)
72Blazerod is offline   Reply With Quote
Old 12-31-2014, 12:25 AM   #2
Rubble
Re: How much can a 1981 1 ton 3+3 4x4 tow?
I've got pretty much the same truck as you are looking at & I don't think it would have any trouble with that.As long as your not too concerned about gas mileage,they like their fuel.My crew used to belong to the neighbors & it was their main trailer pulling truck on the farm with lots of loads well over 20-22000lbs gross & she still runs strong! Go for it!
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 12-31-2014, 01:41 AM   #3
dieseldawg142
dieseldawg142's Avatar
could'nt do any better for old school heavy duty
have a '85 k30 crew, same as yours with 4:56's. i tow a 4000lb quad hauler & pack a camper on the truck (around 3k, give or take...) and i live right beside the "coke"
put half to 2/3rds of your vacation money aside for fuel! i manage about 5mpg in the valley & drop to around 3 past Hope. i weighed my set-up at the Laidlaw scales- 15k truck & trailer. did anybody mention fuel?
plan your vacation route by gas stations...
pulling a 29 footer, leave the t400 in, strong & good on the mountains, you would hardly ever get to lockup with a od with the hills & weight anyways...
k30's dont turn worth a darn, especially when your 20 feet long with another 30 hanging off the back-go wide on the corners or you might get a pedestrian stuck in your awning...
if i hit the "smasher" at 65, i can still manage an easy 50 at the top without straining the truck
carry jerry cans...
dieseldawg142 is offline   Reply With Quote
Old 12-31-2014, 01:44 AM   #4
66LSx
66LSx's Avatar
Cummins conversion into the 3+3... pull a house down and get the MPG back....
minus the stacks and 4x4
https://www.youtube.com/watch?v=kS6262VvdYU
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 12-31-2014, 10:11 AM   #5
xrcr
How much can you stop??
xrcr is offline   Reply With Quote
Old 12-31-2014, 11:03 AM   #6
86c20
86c20's Avatar
diesel. diesel go for a diesel swap. 6.2 will do it but slow......reallly slow. cummins 6b best for the swap and ez too. drop the 400 and go with a 6 speed with the cummins. it will ruin a 400 have seen it a few times.
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 12-31-2014, 12:06 PM   #7
slotard
That's a bumper pull trailer right? SRW or DRW?
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 12-31-2014, 03:43 PM   #8
bryce6horse
bryce6horse's Avatar
I tow a 2014 27ft fifth wheel with 1 slide with a goose neck adapter mounted on the trailer with my 1986 k20 regular cab. It has 350/TH400 for drive line. The trailer weighs 7000 lbs. I can run about 65 down the highway with no problems but when it comes to some inclines I am being passed like I am sitting still.
Rodney
1974 Chevy Big 10
1983 GMC Sierra Classic 1500
1986 Chevy K20
2013 Dodge Challenger
2014 GMC Sierra
bryce6horse is offline   Reply With Quote
Old 12-31-2014, 05:01 PM   #9
mattybilt79
Tow ratings varied a little year to year and I can't find the rating for 81 exactly gm heritage center is a good website for year specific info. That being said I can't see the tow rating being less than 7500 lbs I know that's a low ball number but k trucks had lower ratings. Personally my 85 dually is rated for 10k (2wd camper special). I also pull a 5th with a gooseneck adapter trailer is 6600 dry I assume 7500 loaded up. Truck has a 454 pulls trailer no problem but likes gas as stated also. I plan on a Cummins swap eventually also. I'm sure it would be fine to pull your trailer but would obviously have the brakes and major components checked out on a 34 year old truck before you do. Besides you can never go wrong with a k30!
85 3+3 with a tee-pee
mattybilt79 is offline   Reply With Quote
Old 01-01-2015, 05:39 AM   #10
Puke160
I have an 82 c20 with a 350 and a 400 turbo transmission. I've rolled across the scales hauling scrap metal at 34,500 pounds. There aren't any mountains here but there are a few pretty good hills here, and I pulled them just fine. I don't know what your torque curve looks like on you 454 but few you can try and hold your RPM's at the top of the curve and you will be fine. The 400 turbo is geared low enough and depending on what gears you have in the axles, you will be able to pull no problem. With most of the trucks I have ran pulling is not the problem, it's stopping.
1949 Chevy C3100
1979 GMC K25
1982 Chevy C20
2000 Chevy K2500
2002 Pontiac Trans Am
Puke160 is offline   Reply With Quote
Old 01-02-2015, 01:14 PM   #11
slotard
This is a different year (I think 78), but they didn't change much
1973 C20, 350/350
Old 01-02-2015, 03:01 PM   #12
v30crewcab
v30crewcab's Avatar
7K for a k30? i've had two 7K trucks on a trailer behind mine. didn't even notice it was there hardly. stopping will be the only issue. just gotta think ahead.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 01-02-2015, 06:48 PM   #13
slotard
I don't know that the chart is accurate, just found it somewhere else on this forum. Seems strange that trailer weight on the K is so much less than the C.
1973 C20, 350/350
Old 01-06-2015, 12:14 AM   #14
Puke160
This is a vin chart for GM trucks from 1981 to 1991. As long as you still have the factory hydraulic brakes on your truck, and they are in good shape. This is the factory recommended maximum GVWR if you have changed the brakes this will change also.
1949 Chevy C3100
1979 GMC K25
1982 Chevy C20
2000 Chevy K2500
Old 01-06-2015, 02:00 AM   #15
Keith Seymore
Keith Seymore's Avatar
GVWR is different than trailering.
Gross Vehicle Weight Rating is how much you can put in the box, plus the weight of the rest of the truck, too. (ie, GVWR = curb weight + payload).
Trailering is defined either by the trailer weight alone, or the Gross Combination Weight Rating (GCWR).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
