Old 12-31-2014, 12:36 AM   #1
83swb
Grounds?
I'm working on reassembling my truck, and over the course of 3 years I've forgot what grounds I need, and which ones go where. Not to mention wiring is rocket science to me.
The frame and harnesses are original for an 84 C10 (mildly hacked), but the cab and internals are from an unmolested 87' R20.
I know the basics, negative cable to block, tank sending unit strap, taillight grounds, and headlight/marker grounds. I vaguely remember there being a strap between the cab floor and the frame on the drivers side, but I can't find one on the 87' cab, should I run one?
Is there anything I'm looking over? I like pictures and schematics.
83swb is offline   Reply With Quote
Old 12-31-2014, 01:34 AM   #2
Just call me Sean
Just call me Sean's Avatar
Re: Grounds?
You can't have too many grounds.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 12-31-2014, 10:19 AM   #3
Dead Parrot
Re: Grounds?
On my 75, there is one from the firewall to the passenger side back outside valve cover bolt. Now would be a good time to replace both battery cables. Get one for the negative side that has both the main cable for the block and also has a smaller short wire and connect the smaller wire to the fender.
Dead Parrot is offline   Reply With Quote
Old 12-31-2014, 11:03 AM   #4
hatzie
Moderator
hatzie's Avatar
Re: Grounds?
I have several grounds... Stock???
All of the squares with the Delco SI alternators run the battery ground to the alternator bracket.
I have a 6.5L transplant.
I ran the heavy battery grounds to the frame rails near the motor mount.
Heavy braided straps from the motor mount bolt on the block to the frame stud attached to the battery cables on both sides.
From both batteries to the inner fenders. (Small Gauge wire direct to battery)
Braided strap from the frame to the radiator support.
Braided strap from the rear of one cylinder head to the firewall.
Braided strap from the inner fender to the heater fan retaining bolts.
Braided strap from the frame to the bed on both sides.
I've seen braided straps from the inner fenders to the hood dangling along the hinges on some HAM operators trucks. I didn't bother with those.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-31-2014, 12:44 PM   #5
Bigstevex4
Bigstevex4's Avatar
Re: Grounds?
There are grounds for head lights park lights on each side front 1 in rear under tail light.
Bigstevex4 is offline   Reply With Quote
Old 12-31-2014, 01:13 PM   #6
gmachinz
Re: Grounds?
The front lighting harness has a ground on each side of the core support. The RH ground location also has a 10ga ground to frame and to negative terminal of the battery. There are two ways to make sure you have a good ground-use either grounding ring terminals OR if using regular ring terminals make sure to also use a grounding washer underneath it. The grounding terminals and washers have teeth to "bite into" the metal for good contact through the paint.
gmachinz is offline   Reply With Quote
Old 12-31-2014, 01:25 PM   #7
Bigstevex4
Bigstevex4's Avatar
Re: Grounds?
Do you think those star like washers make areal good ground? I grind paint off put dialectric grease and bolt surface to surface . i couldnt get my Road Glide to make agood ground with them.
Old 12-31-2014, 01:56 PM   #8
gmachinz
Re: Grounds?
Yes....they break into the surface and bite. Its better than laying flat.
Old 12-31-2014, 03:03 PM   #9
rich weyand
rich weyand's Avatar
Re: Grounds?
Grounding is easy to think through. The battery, the engine, the frame, and the cab are all isolated from each other by rubber mounts and the like. Their grounds all need to be hooked together for electrical stuff to work. Four things need to be hooked together, so there are three grounds required to hook them together.
1) The big one that handles the starter current connects from the battery to the alternator bracket. That connects the engine and battery together.
2) That battery cable also includes a smaller gauge wire for connection to the radiator cross-member right by the battery. That handles the frame connection to the battery.
3) A copper braid connects from the passenger side outboard rear valve cover bolt to the firewall. That handles the cab connection to the engine. You can use a 12AWG wire instead of the braid if you want. The valve cover bolt is where many are connected; better is to hook to one of the accessory mount holes on the back of the head.
So you can see the ground connections are frame to battery to engine to cab. Only the one from the battery to the engine needs to be a really big wire, as it handles the starter current.
In addition, every item that uses electricity has to connect to the battery, the engine, the frame, or the cab to complete the electrical circuit. The starter only has the hot wire to it; it grounds through the engine. The heater blower motor only has the hot wire to it, it grounds through its own frame to the firewall of the cab when you bolt it down. The front lights need a ground to the frame on each side, the tail lights use a ground connection to the frame on one side, with a ground wire traveling across to the other side. (Note: I think some years had tail light grounds on both sides.) There are things in the cab/dash that ground to a multi-bladed ground bar up under the dash next to the parking brake pedal bracket.
That's it really.
Oh, and do replace both battery cables. At some point after 10 years, they corrode internally and give hard starting with no outward sign of anything being wrong.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 12-31-2014, 03:12 PM   #10
83swb
Re: Grounds?
Thank you very much for that, definitely cleared it up.
Old 12-31-2014, 04:34 PM   #11
rich weyand
Re: Grounds?
Glad to help. Sometimes we over-think things, and make them harder than they need to be.
Rich Weyand
1978 K10 RCSB DD.
