01-01-2015, 02:12 PM | #1 |
Guest
Posts: n/a
HELP! what replacement panels are worth using
I just received me order from LMC truck. I guess I opted for the NFL delivery. so what wasent bent or dented is TERRIBLE. I ordered right rear lower bed side, right front lower bed side and they look to have been made in a sheet metal. break. The rear corner is HORRIBLE and does not even match.
Whos got the right stuff? I need rockers cab corners and right bed sides. Thanks |
01-01-2015, 02:30 PM | #2 | |
Re: HALP! what replacement panels are worth a ****
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
01-01-2015, 03:04 PM | #3 |
Guest
Posts: n/a
Hello to you to
01-01-2015, 03:11 PM | #4 |
Another Utah Member, MAC71 just picked up a donor cab with one of his projects. Not sure what his plans are, but the cab is super clean. Find him and ask him, maybe he will part out
01-01-2015, 03:14 PM | #5 |
Southern Kentucky Classics, http://sokyclassics.com, have some really nice pieces and GMCPaul who is a vendor on here has some nice pieces too.
01-01-2015, 05:18 PM | #6 |
Re: HELP! what replacement panels are worth using
Check out the Vendor Marketplace. There are several vendors there that sell quality parts and their advertising helps keep the board solvent.
http://67-72chevytrucks.com/vboard/f...play.php?f=195
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
01-01-2015, 05:38 PM | #7 |
Ah shoot ~
The most basic thing is to always ask before buying : where is it made ? if not American at best it'll be cheapo tin foil , most need serious work to fit at all . I'm bummed because my old cab had PERFECT corners and I told him not to junk it but he cut it up and tossed everything but the perfect roof , dammit . I would have GIVEN AWAY those perfect , no rust original paint inside & out corners because I know how hard they can be to come by . For bed parts , Mar-K is the very best there is ~ American made and top quality that fits and is the proper gauge steel etc. They sell direct too , no need to pay extra ' handling charges ' to your favorite Parthsaus .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
01-01-2015, 06:23 PM | #8 |
N.O.S. rockers come up on board here quite often. I would recommend you ask around for some.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
01-02-2015, 12:18 PM | #9 |
Guest
Posts: n/a
Sweet I will check these sources. I was unaware we made ANYTHING anymore. N.O.S. usually means insanity pricing for seconds the factory didnt want to put on a vehicle?.
01-02-2015, 01:30 PM | #10 | |
Guest
Posts: n/a
