Anybody use this Booster Master combo
I'm looking for a new master cylinder booster combo, this one looks like a good deal on Ebay. Anybody use this? Any feedback would be appreciated.
http://www.ebay.com/itm/330948170372...%3AMEBIDX%3AIT
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
Re: Anybody use this Booster Master combo
That picture looks really familiar lol I just ordered that booster two days ago. Should be here in a week, but won't be able to install and use it until I get the firewall painted and brake lines ran.
Thanks for the response. Let me know what you think about the quality once you receive it. My firewall is all painted up and ready for a booster and would like to know if it is a quality piece.
Cheers Ken
it looks a lot like the one i purchessed from NAPA last year for my 3/4 ton 70 GMC. Works great. I'm happy with mine.
1970 3/4 ton long box GMC !968 C10 short stepside (Papa's Old Lorry) 2006 2500 HD Silverado Duramax/Alison |
Yes sir, I'll let you know.
![]() Join Date: Feb 2010
Very interested in this also as I'm changing to disk front brakes
1980c-10 mybaby |
I have the entire 4-wheel disc kit (with that booster and master) from the same eBay vendor on my '68.
I have no complaints with mine, the install really seemed to go smoothly and the quality was better than I expected for the price I paid. I don't have very many miles on the set-up at this point, but it has been trouble free so far! You'll probably want to paint the master cylinder and proportioning valve bracket before installation.......the master will start getting surface rust quickly if you don't. The installation is on page 5&6 of my build thread.....I had to find an adapter for the proportioning valve output but that part number is in the thread too if you need it. Please ignore the ugly firewall......I hope to get that MUCH better looking when the engine swap (finally) happens. I hope that helps.
1968 SWB Stepside "Bella coming home" "Bella's Build Thread" A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack |
Thanks Pick. I checked out your build thread nice truck and good upgrades. It's funny you machine turbines for a living. I operate and maintain industrial gas turbines. We operate both Rolls Royce and Solar industrial gas turbines. Not many people understand what goes into making a turbine work.
#9 | |
Yea with the Rolls Royce Energy Turbine and Gas Compressor business being bought out by Siemens you could see some Rolls business coming your way.
![]() Join Date: Nov 2001
Use an actual Truck part supplier.
http://www.tuckersparts.com/Power-Br...-FPB-6772.html or try one of the vendors on the vendor list on this site.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
Kennuck,I got that booster and master in today. A lot sooner than I thought. It looks great and looks like it has quality pieces on it. Hope this helps in your decision.
#13 |
Old member
Installed the one in the link. Looks like the same one only mine is chrome.
I had to order a new proportioning valve since I went to all disc brakes. The brake light switch had to be modified for the connection to work on it. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=651954
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 01-03-2015 at 06:09 PM. |
#14 |
7 in dual diaphragm booster with standard master and prop valve for disc-disc. Works like a champ.
#15 |
Old member
Fitz,
looks like we both used the same setup. I took the plastic stop light switch out of the valve and trimed the plastic down so the factory connector would work on it. It works fine. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#16 |
Thanks for all the replies guys. I ordered a reman booster and master today, decided to keep it stock. Sounds like this would be a good option though.
