![]() Join Date: Nov 2007
1985 4x4 Crate Engine Swap old school 350 or Vortec 350
Need to put an engine in my 84 4x4, 305 at this time. Thinking of ordering a GM crate engine. Would it be better to put a carbureted Vortec in it or go back with a regular 350? Much problems with the updated Vortec motor swap?
Thanks, Tim |
Re: 1985 4x4 Crate Engine Swap old school 350 or Vortec 350
Go vortec more torque under the curve, and a roller cam. Which is suitable for today's zinc free oils.
I want one for my 4x4 build with full bolt-ons, and maybe a slightly bigger cam. I fantasize about a turbo, but it would likely kill parts. |
For a vortec You will most likely need a electric fuel pump and a regulator with a return line. Everythin else should bolt right up with the exception of the intake.
Vortex without a doubt...thinking of doing a 5.7 in my 10 cheap and easy to come by, junkyards are full of them. Really want a 5.3 but with my budget right now...
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
why not have a custom engine built… can get one just as cheap or cheaper than a vortex or standard chevy crate motor from GM… better components, stronger, will last longer etc. thats's what i would do, (it's what I did) use the savings for something else for your truck
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
Please fellas, its Vortec.
blah, ok Vortec… still would be cheaper to have a custom engine built...
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy Last edited by naphtali5725; 01-02-2015 at 06:39 PM. Reason: BLAME SPELL CHECK |
I'm building a small block 400 with Vortec heads. Similar to these,
http://www.hotrod.com/how-to/engine/...k-chevy-build/ http://www.hotrod.com/how-to/engine/...-block-engine/ http://www.hotrod.com/events/coverag...c-small-block/ |
I went with the base 350 crate and cammed it for torque. No other changes.
New engine, lots of torque, cheap.
Rich Weyand 1978 K10 RCSB DD. |
Doesn't GM make a 383 Vortec? If money was no object that should be a consideration.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
![]() Join Date: Apr 2009
Just curious to everyone who says build an engine is cheaper then a crate motor.If your talking rings and bearings, new gaskets, and hand lapping the valves which is basically a garage freshen up, maybe its cheaper.
IMO if you price up all the parts and the "proper" machine work, its not cheaper. Anyone who can show me a machine shop that will do all the machine work cheaper I would love to start using them. All my engine blocks get this labor.(350 Priced) 1. hot tank block 2. mag block for cracks 3. deck block (if needed) 4. .030 bore on cylinders 5. line bore 6. clean all oil galleys 7. cam bearings installed This is ONLY the block labor, not including cylinder heads overhauled, or any parts. usually come out to about 55% of a new crate motor. Is it a better engine then a crate motor?, of course, but cheaper? I don't think so. Desert |
#12 | |
Desert, what did you pay ? I had a 500hp/500tq Pontiac 461 built with all new parts.. eagle rotating assembly, balanced, custom forged pistons, hyd roller, all machine work as you listed, new valves/springs/locks/keepers, comp valve job, heads mag'd etc. etc. etc. no used anything... 5800.00 Oldsmobile 461, same type components and all machine work as the Pontiac… 4500.00 Parts for Olds/Pontiac are way more expensive than SBC parts... so i know for sure I could have a small block chevy engine built with lots o power, for as cheap as an out of the box new motor from scoggins dickey… Unless he just wants a completely stock 200hp motor... just have to check around, plenty of options out there..cheaply on the money side, not the workmanship if you want the shop names, let me know ![]()
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy Last edited by naphtali5725; 01-03-2015 at 10:22 AM. |
#13 |
Base 350 with torquer cam: under $1700 for 285 hp, 420+ lbft.
#14 |
Trying to keep it under $2000.00. Most rebuilding prices I have found $1500.00 to $1650.00 with my core.
#15 |
#16 |
yeah, with a low budget like that, not much can be done except a good solid stock type + a good cam like rich said… but there's always nitrous lol
#17 |
#18 |
The GM crate motors are great value;all new parts and a GM warrantee.We do not rebuild motors anymore except custom applications or matching numbers originals.
#19 | |
http://www.jegs.com/i/Chevrolet+Perf...30283/10002/-1
#20 | |
#21 | |
That is the one I would want, roller cam, Vortec heads, 1pc rear seal. The engine I posted for him is a direct drop in with the least expense. With the Vortec crate, a different flexplate/flywheel is needed, different intake manifold, throttle cable braket will need to be modified or a different one purchased and an electric fuel pump will be needed as this block does not have provision for mechanical fuel pump. |
#22 | |
#23 |
Everyone is forgetting to go to a vortec engine is going to be more than just an engine. You will need a lot of extra stuff, a bunch of time, and a whole lot of patience.
There is a reason why crate motors exist for our trucks.. to simply keep costs down and keep it simple. |
#24 |
I am going though the same thing myself. I planned on rebuilding the 350 cu.in 4 bolt. I tore it apart to find out the block was cracked on #8 hole in the valley . the best part it had 305 heads on it.
For me to build a 350 4 bolt at the local engine shop I will have well over $ 1500.00 tied up. I plan on going with a GM grate from local GM dealer.It will be the 290 horse 4 bolt as the block I had was a 2 piece rear seal so I dont have to change my flywheel. With going crate you have a milage and year warranty to boot. |
#25 |
Do NOT go with the 350/290hp GM crate engine. All it is (for an extra $500) is the 350/260hp crate engine with the cam out of a 1967 Corvette 350/350hp high-compression engine. In particular, it has high overlap that reduces dynamic compression at low rpms, which, with a high-compression engine, you can afford to give up and it allows more advance because the low dynamic compression at low rpms will reduce the tendency to knock.
What a cam like that means on a low-compression engine is that you will have no bottom end at all. It will completely suck in a truck until you get 3000 rpms under it. It is also a very old cam design, without the high-speed ramps and computerized design of modern products. Also, the fuel mileage will completely suck. We're talking mid-single-digits here. On the other hand, it will be a two-lane terror with a really nice 50-90 time with your foot in it. I went this route myself, and ended up recamming the motor. Since the only difference between the 350/260hp and 350/290hp crate engines is the cam, I could have saved the extra $500 (and the expense of changing out the cam), and just gone with the 350/260hp crate engine and recammed it from the get go. After all of this, my recommendation for a cheap performer is the #10067353 350/260hp crate engine, with a Comp Cams 12-235-2 cam. That's the cam Sean Murphy over at SMI recommended to me a couple years back, and several people have gone with it and liked it. With headers and a dual-plane manifold, you'll see 290hp @4000 and 415lbft @2500, which is a really nice torque number down low where you want it. You should upgrade the springs with this cam, but that's it. If you put it in a never-run 350 crate engine, you don't even need to change out the lifters. I went with the Comp Cams 12-300-4 cam, which gives 275hp @4000 and 423 lbft @2500. No spring change required, but I did lower the shift points 500 rpm at WOT by changing out one weight on the transmission governor, which is a half-hour job. But if you go with the 350/290hp crate engine, you will be disappointed. Been there, done that.
