Vision Legend 6
Anybody running vision legends on their truck. I'm looking at 17x8s with 0mm offset and 4.5" of backspacing. I really like the look of the wheel. Not so sure about the hub diameter though.
![]() Join Date: Aug 2013
Re: Vision Legend 6
Interested in responses, I have been looking at them for my 65 also.
Jim |
Re: Vision Legend 6
Looks like the hub diameter on these are way too small to run on stock hubs.
Re: Vision Legend 6
I put them on my 64. I have disc on the front so there was no problems. On the rear I did have to machine the wheels to fit over the hub on the drum. I am running different size tires so there is no reason to rotate them.
Re: Vision Legend 6
They do look good. What size tire are you running? And how much drop do you have? Im kinda working backwards here. At this point I'm just trying to get the truck back on the road and make it a driving project. I may go with some junkyard steelies until I can convert to disk brakes and go from there.
Re: Vision Legend 6
225-50 front 225-55 rear. Front has 2 1/2 spindles and 3 inch springs. The rear are 5 inch springs. Lower then it looks but never have a problem rubbing or bottoming out.
