Old 01-01-2015, 09:21 PM   #1
wideopen1967
wideopen1967's Avatar
Sound / heat mat
What is the best stuff for the money? Want to use some on my 81.
wideopen1967 is offline   Reply With Quote
Old 01-02-2015, 03:02 AM   #2
andrewmp6
Re: Sound / heat mat
If you want spray on http://www.lizardskin.com/ stick down would be http://www.dynamat.com/ or http://www.designengineering.com/cat...tical-products has a few options.
andrewmp6 is offline   Reply With Quote
Old 01-02-2015, 06:41 AM   #3
NJ C10 Guy
www.sounddeadenershowdown.com
NJ C10 Guy is offline   Reply With Quote
Old 01-02-2015, 11:38 AM   #4
77K10Silverado
77K10Silverado's Avatar
http://www.fatmat.com
77K10Silverado is offline   Reply With Quote
Old 01-02-2015, 01:50 PM   #5
MikeB
MikeB's Avatar
I like RAAMmat BXT for sound deadening (panel vibration dampening). It works as well as DynaMAT Xtreme and costs a lot less.
http://www.raamaudio.com/categories/...Foam-Products/
For a heat barrier, lay some of this on top of the RAAMmat:
http://www.competitionproducts.com/T.../#.VKbY99LF98E
It's essentially blue jean fibers with a foil backing that will lower your floor temperature substantially.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-02-2015, 06:25 PM   #6
UKNOWME
UKNOWME's Avatar
I had a member on another forum suggest adhesive asphalt flashing. He said it works almost as well as Dynamat and is about 1/3 the price.
http://www.lowes.com/pd_124018-81326...7C1&facetInfo=
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 01-02-2015, 06:38 PM   #7
Russ_the_truck79
If anyone reading is shoestring budget looking for a temporary fix I've found that a big piece of memory foam under the seat soaks up enough sound to have conversations at highway speed even when you have worn out door seals and a whole in the floor. doesn't help on the heating side of things though...
could of had an air conditioned honda but,
I'm hard headed and have standards
Russ_the_truck79 is offline   Reply With Quote
Old 01-02-2015, 07:12 PM   #8
wideopen1967
I have been doing a lot of reading on this. Sounds interesting. Cant beat the price, and it is butyl rubber so it shouldn't smell;
http://www.lowes.com/pd_495919-46086...ber&facetInfo=
Old 01-02-2015, 08:05 PM   #9
NJ C10 Guy
It's rubberized asphalt, not butyl rubber. There is a difference.
Edit: I clicked on the wrong link. What you linked is butyl rubber, but damn it's small. Seems like it would take a while to lay down.
Old 01-02-2015, 10:36 PM   #10
wideopen1967
The ad says 37.5 square ft. Any idea how big the pieces are?
Old 01-03-2015, 12:19 AM   #11
UKNOWME
UKNOWME's Avatar
That was just an example. I'm sure there are other options
1964 Chevy c10
Old 01-03-2015, 02:08 AM   #12
TKCR
TKCR's Avatar
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
http://www.homedepot.com/p/UltraTouc...8?N=5yc1vZbedf
I used both of these products. It was far cheaper the the Fatmat or DynaMat before installing my new carpet.
Old 01-03-2015, 08:04 AM   #13
homemade87
I used the fatmat and worked well . I would suggest getting enough to do the ceiling ( if have a headliner). Also the doors . I put just enough to the outer skin on the inside of the door and also covered the inside of the door behind the door panel . What a difference it made . They even sound solid when closing the door now instead of the hollow tin sound . I am confident it took a lot of my interior noise out .
homemade87 is offline   Reply With Quote
Old 01-03-2015, 11:50 AM   #14
TKCR
TKCR's Avatar
I also used that adhesive on the ceiling under the headliner and inside the door. I did the same as you on the doors, used some on the door skin under the door panel and on the door panel itself.
I had some FatMat left over that I used from a previous vehicle I did, but it was so expensive compared to the stuff you can run to Lowes and get. I compared the 2 side by side, and there is no difference in thickness. It looked the same, felt the same. The only difference I could see, is that the FatMat had its logo printed on it.
It truly has made a bring improvement on the sound. And then putting the heat mat from Home Depot, I feel helped also. I used it everywhere I could think of.
Old 01-03-2015, 12:41 PM   #15
1968vetL-71
Junior Member
1968vetL-71's Avatar
Used the Lowes product in my 91 crew. Took a bit of time, but I'm kinda anal about keeping lines straight. I taped all the seams and edges also. Works great!! What a difference.
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 01-03-2015, 05:37 PM   #16
Domer
Domer's Avatar
So i used to preach about Fatmat, and the similar types of stick down insulation. My 77 Pro street( 6-71 blown sbc) thats bagged and body dropped. I had 3 layers on the floor, my firewall was done, and my doors inside and out. while it did good for sound, i melted it, and my carpet was stuck to it. it seeps up through the edges. I also did my 97 crew cab , as it is my tow rig. Also melted through on the floor and actually got so hot, that my wife couldnt put here feet on the floor as it would burn her. We were towing through nevada in 105 degree weather. and i live in socal where its always warm. that being said, i am now gonna use Lizardskin on my new build. and see how it holds it up to heat. Also on my 77 the inside of the cab was always really hot. never needed a heater at all..
Domer is offline   Reply With Quote
Old 01-03-2015, 05:44 PM   #17
MikeB
MikeB's Avatar
37.5 sq ft per flat pack box, 20 sheets, 11"x23"
I liked it better when it came in rolls.
Mike
