Old 01-01-2015, 10:45 PM   #1
SoCoC10
SoCoC10's Avatar
C20 long bed farm truck to C10 short bed driver
After realizing I can never take my 65 Chevelle SS to Walmart. I am going to temper my need to make this truck perfect and just make it better than when I got it. The truck is Fremont, CA built C20 long bed that was sold locally here in Colorado Springs at Daniel's Chevrolet. Plans are to convert the 8 lug drum front end to 5 lug disc brakes, 5 lug rear diff. drop it 4-5" in the front and 6-7". Shorten the frame and convert the long bed to a short bed. Roll it on some 20" Boss 338s.
Have not done much to it yet,just fixed a coolant leak, wet sanded the primer spots and sprayed some rattle white. Removed the ugly broken red horn from the firewall and installed a working horn. If it ever stops snowing I am hoping to get some work done on her soon.
SoCoC10 is offline   Reply With Quote
Old 01-02-2015, 02:57 AM   #2
dmack91
dmack91's Avatar
Re: C20 long bed farm truck to C10 short bed driver
Sounds similar to what my son is doing with his 68 C20. Frame and bed already cut, doing bodywork (when it is above freezing). Just picked up a 78 C10 for donor running gear today.
Keep us posted.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 01-02-2015, 10:21 AM   #3
SoCoC10
SoCoC10's Avatar
I bought the truck because the drivetrain was solid. 350/TH350 that runs and shifts good. The pass/drivers outer rockers have been replaced but not a good job. The pass cab corner and mout are rusted but drivers side is good. Best of luck to you and your son with your truck.
Old 01-02-2015, 12:03 PM   #4
Saclandman
Saclandman's Avatar
Looks like a good place to start. Good luck.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline   Reply With Quote
Old 01-03-2015, 12:15 AM   #5
SoCoC10
SoCoC10's Avatar
Thanks for the words of incouragement. My sister graduated from UC Davis. Orig from San Jose, I spent some time in the Elk Grove area near Sac. Even showed a 67 Nova at the fairgrounds in Sac.
Old 01-03-2015, 01:16 AM   #6
Saclandman
Saclandman's Avatar
Cool. There's several members up in these parts. Where in CO are you. I spent a year there when I was a kid near Durango. Too cold for us Californians.
Rich J.
Old 01-03-2015, 11:45 PM   #7
SoCoC10
SoCoC10's Avatar
Made some progress today. Left side C20 lower control arm, spindle, drum and upper ball joint are removed. Pressed in new lower ball joints in to 84 C10 lower control arms. Toughest part was getting the rivets out of the upper ball joint/control arm.
Old 01-04-2015, 10:04 PM   #8
SoCoC10
SoCoC10's Avatar
Got the right lower control arm installed, the upper ball joint installed, 2" drop coil spring and drop spindle.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
Old 01-04-2015, 10:16 PM   #9
SoCoC10
SoCoC10's Avatar
New standard duty 1" thick rotor, bearings, caliper and brake pads. New KYB GR2 shock. Need brake hoses, tie rods, master cylinder and perportioning valve. Still deciding if I want a booster or not.
Old 01-11-2015, 11:22 AM   #10
SoCoC10
SoCoC10's Avatar
Got the driver's side taken apart yesterday. Hope to get assembled today.
Old 01-11-2015, 04:39 PM   #11
SoCoC10
SoCoC10's Avatar
Got the driver's side done today. Perportioning valve, front brake lines and tie Rod sleeves coming this week from POL.
Old 01-17-2015, 09:41 PM   #12
SoCoC10
SoCoC10's Avatar
Got these in on Fri. Going to run 20x8.5 fronts and 20X10 rears. Hope to run new brake lines, install new master cylinder and perportioning valve tomorrow.
Old 05-08-2015, 10:33 PM   #13
SoCoC10
SoCoC10's Avatar
Got the brake hardlines done. Finally got the correct rubber brake lines, bled the system and took her for a drive. Need to have the alignment done. Hope to swap the rear diff out sometime next month, but need to put the truck to work on some projects around the house.
Old 05-08-2015, 10:50 PM   #14
tommys72
tommys72's Avatar
Nice work so far. Looks good
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 05-10-2015, 12:59 PM   #15
Mac93
Mac93's Avatar
Wheels look very nice. I see you ran your brake hardlines for the longbed, are you not going to cut it to a shortbed anymore or are you planning on keeping it running and driving till you cut it?
Mac93 is offline   Reply With Quote
Old 05-13-2015, 09:39 PM   #16
SoCoC10
SoCoC10's Avatar
With spring here I'm gonna do a few cosmetic things and leave the long bed alone. My girlfriend has a paddle boat that the longbed might come in handy for. 👍 Mac93 great work on the seat recover.
Old 05-13-2015, 09:58 PM   #17
SoCoC10
SoCoC10's Avatar
Got some paint work done on the truck. My first try at patina. If it would stop thunder showering I could get some paint on the hood.
Old 05-13-2015, 10:08 PM   #18
SoCoC10
SoCoC10's Avatar
Got rid of the all white front end too.
Old 05-13-2015, 11:13 PM   #19
boynton
boynton's Avatar
I have thought about trying this build. Im in for the education. So you used the stock c20 upper a-arms and the '78 lowers with '78 ball joints in both? after you swap the rear are you going to swap the core support and cab bushings to the c10 size or will you have to keep the c20's to keep everything lined up?
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 05-16-2015, 02:00 AM   #20
swamp rat
swamp rat's Avatar
I wouldn't take that truck to Walmart ether! LOL! Nice work so far, amazing how much better it looks with 5 lug wheels.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-02-2015, 10:32 PM   #21
SoCoC10
SoCoC10's Avatar
boynton, I used stock upper control arms with later(73-87) upper ball joints. 86 lower control arms with new 86 lower ball joints. Have not decided on the mounts yet.
Old 06-02-2015, 10:40 PM   #22
SoCoC10
SoCoC10's Avatar
Got some letters and the hood done.
Old 06-09-2015, 07:28 PM   #23
Saclandman
Saclandman's Avatar
Looking good. Keep it up.
Rich J.
Old 06-10-2015, 08:00 AM   #24
Gus350
68 C 10
Gus350's Avatar
Starting to look Killer
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 06-10-2015, 09:32 AM   #25
Xeen
Xeen's Avatar
This pickup has really nice front sheet metal.
It looks great lowered.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
