Old 01-02-2015, 11:28 AM   #1
TheChief
73-87 gauges
any one have a diagram of what leg of each gauge (Oil / Temp / Gas / Volt) go to? im trying to bypass the printed circuit and wire the gauges direct to the truck harness with a new plug.
Thanks in advance.
08 cc silverado dropped on 24's
82 1 ton c30 Dually
TheChief is offline   Reply With Quote
Old 01-02-2015, 06:08 PM   #2
ray_mcavoy
Re: 73-87 gauges
Looking at the gauges from the back:
Voltmeter (pictured above)
Left terminal (marked A) is power
Top terminal (marked B) is ground
Right terminal (marked C) is a junction between the ceramic resistor and the meter's internal windings (don't make any external connections to this terminal)
Bottom terminal is not present
I don't have pictures of the other gauges handy at the moment, but viewing them from the same orientation:
Temperature Gauge:
Left terminal is power
Top terminal is ground
Right terminal is the sending unit
Bottom terminal is a junction between the resistor & meter windings (again, don't make any connection to this terminal)
Fuel Gauge and Electric Oil Pressure Gauge both use the same terminal layout:
Left terminal is the sending unit
Top terminal is not present
Right terminal is power
Bottom terminal is ground
ray_mcavoy is offline   Reply With Quote
Old 01-02-2015, 08:07 PM   #3
Just call me Sean
Just call me Sean's Avatar
Re: 73-87 gauges
Trace the circuit board.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
