Old 01-02-2015, 12:56 PM   #1
MattPSU
MattPSU's Avatar
Drive shaft question - Bagged SWB 72
Now that my 5.3 and 4L60E are installed, I started to look at measuring for a new drive shaft. My truck is a SWB 72 and it's bagged with cups/plates and Porterbuilt's bolt in notch. It originally had a 2 piece drive shaft and I was going to have a one piece made. However, it seems that it'll hit the upper part of the cross member when lowered. I attached a long 1x1 to the yolk and ran it to the rear end then lowered it and the 1x1 is really close to the upper part of the cross member when laid out. Is anyone else running a similar set up with a one piece drive shaft?
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 01-02-2015, 08:11 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Drive shaft question - Bagged SWB 72
Other are, but usually with a notch in the crossmember. Are you hitting the cab bottom or the actual trailing arm xmember?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-02-2015, 10:46 PM   #3
kotapug
I have a 6.2 with a 6l80e with a 1 piece drive shaft and mine hits the 4-link and the cab . I will have to modify both
kotapug is offline   Reply With Quote
Old 01-02-2015, 11:14 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Porterbuilt sells a perfect tubular trailing arm crossmember to solve your issue.
Definitely go to the 1-piece driveshaft.
Keith
Convert to disc brakes.
Old 01-03-2015, 07:14 PM   #5
MattPSU
MattPSU's Avatar
I'm hitting the cross member. Am I OK to trim it a little?
Old 01-03-2015, 08:55 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If I were the one trimming, I would cut as little as possible and try to reinforce it where I could. Its the point-of connection for your suspension components, so you want it strong.
If I was gonna have an agressive engine combo or race it etc, I'd be way more inclined to go with an aftermarket (or just fab) a new xmember.
Just as a thought, you can also get slightly narrower driveshafts built as custom shops if your willing to pay a little. Not sure how much space you're looking to gain.
Old 01-04-2015, 05:57 PM   #7
kitsbeach
kitsbeach's Avatar
Keith you like the one piece driveshafts best.?
I have no opinion on it but it seems to me like the two-piece solves some of the problems when the truck is lowered. And since mine is in good shape and recently rebuilt I could just do a quick shorten when the time comes. Plus I know semi-trucks use two-piece so there shouldn't be a problem with strength.
Like I said I have no opinion or experience with this. Just wondering what your thoughts are....
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
Old 01-04-2015, 06:05 PM   #8
lolife99
lolife99's Avatar
I seem to have trouble finding a good oem carrier bearing.
1-piece is just simpler in my mind.
Keith
Old 01-04-2015, 06:07 PM   #9
lolife99
lolife99's Avatar
2-piece drive lines on lowered trucks need to have a slip yoke in the rear shaft.
Most 67-72 2wd trucks do not. Except the factory 4-speed trucks.
Keith
Old 01-04-2015, 10:00 PM   #10
MattPSU
MattPSU's Avatar
Thanks for all of the feedback guys. I finally had a chance to really look at things. Seems that I'm hitting the bracket for the center bearing, not the cross member itself. Looks like I can remove it and have plenty of clearance.
Just when I thought I was done drilling/cutting out rivets...
Old 01-05-2015, 04:25 AM   #11
kitsbeach
kitsbeach's Avatar
Thanks Keith. It is probably simpler and for a short bed we are not talking about a long driveshaft. My '67 shaft has the slip yoke in it. It's a three on the tree truck but had a four-speed put in it at one time. I've just recently changed it back to three on the tree for nostalgia. Planning an LS and 6-speed later down the road.
Kitsbeach (Ken)
Old 01-05-2015, 08:53 AM   #12
lolife99
lolife99's Avatar
I was referring to a slip yoke on the REAR shaft of a two piece driveline.
The bottom drive shaft has a slip yoke at the carrier bearig.
The driveshaft directly above it does not.
Both are found in 67-72 longbed and short bed trucks.
Keith
Old 01-05-2015, 12:14 PM   #13
Hart_Rod
Hart_Rod's Avatar
Keith - it depends on the driveshaft diameter also. I had a 3.5" DS because of the HP in my gold truck with a PB TA crossmember, PB 3" drop trailing arms, and 5" dropped springs. The DS was very, very close to the top of the crossmember. If I had it to do over, I would have modified the PT crossmember OR just went with a 2 piece DS so you don't have to worry about it.
Hart_Rod is offline   Reply With Quote
