Old 01-02-2015, 07:48 PM   #1
michael bustamante
michael bustamante's Avatar
door hinge replacement
any of you guys have any tips or tricks on replacing the door hinges?
my driver door is dropping a good bit when opening and im getting tired of slamming it shut.
im not replacing the bushings as im sure the holes are wallered out so im remplacing the full assemblies
1967custom
michael bustamante is offline   Reply With Quote
Old 01-02-2015, 08:19 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: door hinge replacement
I find it easier to remove the gauges to access the bolt from under the dash You can try using a floor jack to hold the door in place and try to replace the hinges one at a time
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-02-2015, 09:55 PM   #3
tucsonjwt
Here is my post on replacing the door hinges. Once I had the correct gm pins and bushings it wasn't too bad when I used a homemade platform for the door made out of scrap 2 x 4s. I would not assume that your hinges cannot be reused - the bushings will be worn out but it is a lot easier to replace them than the whole hinge.
http://67-72chevytrucks.com/vboard/s...ght=door+hinge
tucsonjwt is offline   Reply With Quote
Old 01-02-2015, 10:29 PM   #4
michael bustamante
Theyre worn pretty good. I assume i have to remove the hood and fender?
1967custom
Old 01-02-2015, 10:30 PM   #5
77K10Silverado
77K10Silverado's Avatar
I have a little in my thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=635286
77K10Silverado is offline   Reply With Quote
Old 01-03-2015, 11:04 AM   #6
old Rusty C10
no you don't need to remove the nose to get them out just being able to move the door ive done it with extensions and swvels
Bob
I hate cancer!!
Old 01-03-2015, 11:47 AM   #7
pontiac6269
pontiac6269's Avatar
I did this on my 81 C20 drivers door a couple months ago. I removed the door and left the hinges attached to the cab. Cut the pins to remove them. Drilled the pin holes out so the bushings would fit snug in the holes(I used the bushings with the splines). I didn't have a big enough drill bit, had to file the holes to size. Cleaned up any burs and wire brushed grease and rust. Installed bushings, outer half of hinge and pins. I usually put a spot weld on the end of the pin. Reinstall the door and align. I also got a new striker as mine was shot. The door shuts like it is new, no lifting and slamming, bouncing and rattles when driving. I still have to do my passenger door and need new door and window seals but that won't happen until it is painted, whenever that happens.
Eric
2001 Ford F350 EC dually 7.3
1981 Chevy C20 to K20 350
1978 Oldsmobile Cutlass Supreme 455 Pontiac
1969 Pontiac GTO 400
pontiac6269 is offline   Reply With Quote
Old 01-03-2015, 01:21 PM   #8
ont_guy_38
ont_guy_38's Avatar
Used the oversize bushings lots of times, something to consider if you haven't bought new hinges yet.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 01-03-2015, 01:38 PM   #9
wideopen1967
wideopen1967's Avatar
Can you recommend a source for the oversized bushings?
wideopen1967 is offline   Reply With Quote
Old 01-03-2015, 02:00 PM   #10
pontiac6269
Most of the kits I've bought had both sets of bushings and purchase them from any parts house.
Eric
Old 01-04-2015, 05:37 AM   #11
tucsonjwt
The Dorman hinge pin kit has oversize pins and bushings, as well as the standard size bushings. I bought them first but did not want to ream out the holes in the hinge, so I bought the genuine GM pins and bushings which worked best for me. So, you can buy a Dorman kit from any parts store and check it out on your truck. You may find that you need the stock size parts, and I prefer GM OEM whenever possible.
Old 01-04-2015, 08:41 AM   #12
Your41Plague12
Your41Plague12's Avatar
I used the Dorman kit from Advance Auto. It came with the standard size bushings as well as the oversized ones. I opted to use the oversized ones. Just drill to the size recommended, and install as you would any door pins. They worked perfectly, and much cheaper than GM ones. They seem to be a little heavier-duty, as well.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 07-07-2017, 10:17 PM   #13
SierraMtns
SierraMtns's Avatar
Where did you buy the OEM ones?
SierraMtns is offline   Reply With Quote
Old 07-08-2017, 01:45 AM   #14
TKCR
TKCR's Avatar
bushings # 9721917
hinge pins # 20046147
These are the GM part numbers, you should be able to go to your local dealership and have them order some.
Old 07-08-2017, 08:59 AM   #15
blazer2007
Mine had a small small spot weld on the pin so I had to grind that off first and then tap the pin out
blazer2007 is offline   Reply With Quote
Old 07-08-2017, 12:29 PM   #16
tucsonjwt
If you buy the Dorman pin/bushing kit the bushings will be oversize, which might take up the slack in your worn out hinge holes.
Old 07-10-2017, 09:17 AM   #17
Pontiac1976
Pontiac1976's Avatar
You did not say what year but I see you 67, the 73-87 trucks pretty close I think the dash area little bit different near the hinge. might be a little easier.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 07-10-2017, 09:44 AM   #18
Jrgunn5150
My Dorman pins didn't fit the included bushings, I wound up buying OEM.
J.R.
Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010
Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer
Jrgunn5150 is offline   Reply With Quote
