Old 01-02-2015, 08:21 PM   #1
pro1956
pro1956's Avatar
58/59 hood on a 56
Anyone know what's involved in putting a 58/59 hood on a 56?
pro1956 is offline   Reply With Quote
Old 01-02-2015, 08:25 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 58/59 hood on a 56
putting 58/9 fender on, then the hood would have a nasty over bite. 55/7 fenders are shorter by 2.5" as is the hood
dwcsr is offline   Reply With Quote
Old 01-02-2015, 08:31 PM   #3
pro1956
pro1956's Avatar
I have seen it done, sounds like a lot of work but I might try shortening up the hood.
Old 01-02-2015, 08:58 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
I might suggest you cut the recess out of a 58 hood and put it in a 56 hood. That would be much easier that modifying a 58 hood to fit a 56
Old 01-02-2015, 11:23 PM   #5
pro1956
pro1956's Avatar
I found a 59 hood I'm going to measure it out and see if I can make it look right. Thanks for the reply.
Old 01-03-2015, 12:09 PM   #6
dyno
dyno's Avatar
So is the distance from the radiator support to the firewall 2.5" shorter on 55-57 compared to 58/59? I'm thinking about buying a 55 and putting a Cummins in it and don't want to cut myself short on room for it.
"Built- not bought"
1958 GMC 150 4x4 in progress
1980 K20- Restored
1985 K3500 Flatbed
58 GMC 4x4 build thread:
http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675
dyno is offline   Reply With Quote
Old 01-03-2015, 12:48 PM   #7
Kabwe
Certified Car Nut
Kabwe's Avatar
Correct way to do it.
Kabwe is offline   Reply With Quote
Old 01-03-2015, 02:59 PM   #8
OrrieG
OrrieG's Avatar
Radiator support to firewall distance is the same 55.5 -59, difference is longer frame rails at front for the longer fenders and hood. Hood hinge mounts are different too early to late.
OrrieG is offline   Reply With Quote
Old 01-03-2015, 05:08 PM   #9
dyno
dyno's Avatar
Thanks for clearing that up Orrie.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
