Old 01-02-2015, 09:01 PM   #1
sKnNyPpY
sKnNyPpY's Avatar
Timing and idle after fan install
Would the drag on an engine be significantly different timing wise after replacing a direct drive fan with a clutch fan? I've had a slight miss since replacing and was fiddling with the idle and have now lost my baseline settings. I had a flex fan with a missing blade and a cobbled up shroud on a '72 350 block in a '71 GMC truck with a long water pump. Replaced with a clutch and fan setup and trimmed a replacement shroud to clear the assembly.
How many (full) turns should I start on the cold idle screw under the choke pull off? And am I thinking properly by going three (full) turns out on the idle mixture screws on the Quadrajet before trying to get the timing to 33-36 total @ 2800-3000 rpm? I have a dial back light and a vacuum gauge. thx
edit: Divorced choke on a Franken carb from a 85 Caddy, the replacement bent coat hanger rod has been working OK for a few months. Proper Edelbrock split bore intake as well.
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
