Old 01-03-2015, 07:22 AM   #1
ol rob
Dropped spindle question
What is the lowest drop spindle I can use and still use aftermarket aluminum 15" wheels? My truck has lowering spindles on it and there is very little clearance between the lower a-arm and the steel ralleys on it now. I want to buy some new wheels, but may have to replace the spindles as well. Call me old school, but I want 15" wheels.
Ol Rob
ol rob is offline   Reply With Quote
Old 01-03-2015, 09:00 AM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Dropped spindle question
Should pose no problems...I think 2-1/2" is the max drop spindle out there. My 15x8's with BFG 60's clear just fine. Might run into fender and fender well clearance issues depending on tire choice. My 72 clears the control arms, stop to stop with no issues. Wheel width and backspacing may pose problems if you go too deep or wide.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 01-03-2015, 06:48 PM   #3
ol rob
Thanks. 15x8is my target front rim size.
Old 01-03-2015, 07:56 PM   #4
BugzC10
BugzC10's Avatar
Backing spacing will be 4" max. Even with 4" BS you may still get the rim rubbing the lower control arm when making a tight turn if the bump stops have been removed.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
