01-03-2015, 11:34 AM | #1 |
66 driveshaft
I have a 66 c10 swb I am wanting to install a 350 with a 350 transmission. I found a mid 70s c10 with both. The truck is a swb. Will the driveshaft out of the mid 70 c10 fit my 66 ?
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
01-03-2015, 07:30 PM | #2 |
Re: 66 driveshaft
NObody knows???
01-03-2015, 08:57 PM | #3 |
Re: 66 driveshaft
I have read somewhere on this site that it will. Be sure and check the proper yoke slip play...
1964 C10 SWB original 1970 SS El Camino 1964 Impala SS http://67-72chevytrucks.com/vboard/s...d.php?t=649951 |
01-03-2015, 10:52 PM | #4 |
Re: 66 driveshaft
I searched but could not find anything. I hope it will work because I am planning on buying the whole truck
01-04-2015, 12:08 AM | #5 |
Re: 66 driveshaft
Really the only way to be sure is to measure it.
01-04-2015, 03:05 AM | #6 |
Re: 66 driveshaft
I believe my drive shaft came from a 72 when the PO was putting the truck together (250 + TH350). When I swapped the engine for my 350 and moved forward (3") I had the shaft re-tubed.
1966 C10 Short Fleetside 1988 Sportster, 2008 Street Glide Ken's 1966 C10 build "Red Ale" Follow on Instgram: @cv_performance https://instagram.com/cv_performance Harley Performance Parts: CV Performance (Harley related) Enjoying the ride! |
01-04-2015, 09:00 AM | #7 |
Re: 66 driveshaft
I guess what I should have asked is a swb 73-85 chevy c10 the same length as a 64-66 c10 swb truck?
01-05-2015, 01:21 AM | #8 |
60-66 Nut
Re: 66 driveshaft
When it comes to driveshafts it is very rare that you can take a driveshaft from one vehicle and have it fit correctly in another vehicle. There are just too many variables. I'd say it is a 50/50 chance it will fit. If it doesn't fit, and hopefully it is too long, just have it shortened.
