01-03-2015, 03:38 PM | #1 |
Dash Pads
Has anybody used USA1 Industries or Ecklers Classic Chevy Trucks dashpads? Looking to buy a new dash and need opinions, should I go with Urethane or Vinyl Style? Thanks!
01-04-2015, 01:24 AM | #2 |
Re: Dash Pads
Bump
01-04-2015, 01:32 AM | #3 |
Post Whore
Re: Dash Pads
no, but made in USA and less than LMC Truck by a $100 bucks, how much is the shipping going to set you back
01-04-2015, 02:00 AM | #4 |
Re: Dash Pads
I bought the urethane one from classic industries. I think it looks really nice. Took a bit of trimming on the ends, but was a pretty easy install.
01-05-2015, 01:30 AM | #5 |
Re: Dash Pads
Sub'd
Interested as well
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
01-05-2015, 12:58 PM | #6 |
Re: Dash Pads
I'd personally go vinyl (which I did). Check out DashesDirect.com too.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
01-05-2015, 01:08 PM | #7 |
Re: Dash Pads
With what dashes cost, I'm considering just doing a custom aluminum dash.
1973 C20, 350/350 |
01-05-2015, 03:38 PM | #8 |
Re: Dash Pads
There is a guy on here that covers them and they look pretty good. Not sure about cost though.
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
01-05-2015, 04:27 PM | #9 |
Re: Dash Pads
i just tried to look stitch up and his account is deactivated
01-05-2015, 05:17 PM | #10 |
Re: Dash Pads
Mine was blue and all cracked, l used a nice 4 way stretch vinyl, some good contact cement and a heat gun. Turned out nice. I also did my door panels to match. I'm into it for about $50.
01-05-2015, 05:30 PM | #11 |
Re: Dash Pads
Wow, I'll have to try that. How long did it take?
1973 C20, 350/350 |
01-05-2015, 05:40 PM | #12 |
Re: Dash Pads
01-05-2015, 06:07 PM | #13 | |
Re: Dash Pads
01-05-2015, 06:17 PM | #14 |
Re: Dash Pads
It was pretty easy, just clean well with wax and grease remover, I think the most important part is using good glue, and only gluing around the edges, so the vinyl "floats" over the cracks. It looks like new, and has held up fine for over a year. I just did the door panels a couple of weeks ago, and they were a little tougher to do than the dash, but turned out nice. I'll see if I can get the name or brand of the vinyl when I get home. It streaches great, and is nice and soft. The dash took about an hour, the door panels took about 2 1/2 hours, that included sewing up new map pockets. When I started my dash and door panels were garbage.
01-05-2015, 06:23 PM | #15 |
Re: Dash Pads
Here is a pic of how the door panels turned out. Now I need to replace the trim around the center panel.
01-05-2015, 10:02 PM | #16 |
Re: Dash Pads
Had my local auto upholster cover mine in vinyl. MUCH better than the aftermarket stuff I've tried. Did headliner and dash for 175.
01-05-2015, 10:18 PM | #17 |
Re: Dash Pads
Try Stitch Rod & Trim on Facebook.
He quoted me 350.00 plus shipping a couple years ago. I think it's a good price considering his work is awesome.
01-05-2015, 10:20 PM | #18 |
Re: Dash Pads
Can you still feel the cracks when you run your hand over the dash?
01-05-2015, 10:35 PM | #19 |
Re: Dash Pads
I'll have to try that. It sure looks nice. If I have a shop do it I'll consider having them redo my seat too.
1973 C20, 350/350 |
01-05-2015, 10:37 PM | #20 |
Re: Dash Pads
01-05-2015, 10:54 PM | #21 |
Re: Dash Pads
Nice job
01-05-2015, 10:59 PM | #22 |
Re: Dash Pads
01-05-2015, 11:07 PM | #23 |
Re: Dash Pads
I also tried their website, same -no luck. www.StitchRodandTrim.com
01-06-2015, 11:53 AM | #24 |
Re: Dash Pads
Chuck Bench aka Stitch 1-803-469-9111
I got his number from Mike Losh aka 67cheby I have his email also but it won't let me post it here. PM me if you want it.
01-06-2015, 04:52 PM | #25 |
Re: Dash Pads
lurk
1981 Chevy C30 440 Holmes 42K one owner miles |
