![]() Join Date: May 2010
Torque converter stall ok size with this cam?
Here is the converter specs
JEGS Performance Products#555-60400 GM TH350/TH400 12" Torque Converter 10.75" Bolt Circle Stall Speed: 2300-2700 RPM Here is my setup 355, 9.5:1 cpr, 670 street avenger, rpm air gap, promaxx vortex heads, Howards cam, long tube headers. The truck is a 72 lwb Cheyenne super with th350. Car is a weekend ride, occasionally driven on the street, car shows etc. Head specs ProMaxx Performance#723-2151 Cast Iron Small Block Chevy Vortec Cylinder Headsł Assembled Straight Plug Intake Ports: 185cc Combustion Chambers: 64cc Valves: 2.02" Intake, 1.60" Exhaust Can specs Cam Style:Hydraulic flat tappet Basic Operating RPM Range:2,800-6,400 Intake Duration at 050 inch Lift:231 Exhaust Duration at 050 inch Lift:231 Duration at 050 inch Lift:231 int./231 exh. Advertised Intake Duration:285 Advertised Exhaust Duration:285 Advertised Duration:285 int./285 exh. Intake Valve Lift with Factory Rocker Arm Ratio:0.480 in. Exhaust Valve Lift with Factory Rocker Arm Ratio:0.480 in. Valve Lift with Factory Rocker Arm Ratio:0.480 int./0.480 exh. Lobe Separation (degrees):108 Is that stall speed in the range? I was thinking it would be OK, if not maybe something in the 2200-2400 range? |
Re: Torque converter stall ok size with this cam?
It will work, but a 10" 3500 rpm stall would be best with that cam performance wise. Second would be an 11" 2800 rpm converter. I had a TCI 2800 rpm stall 11" with a 228 at .050 cam and even with 4.10 gears it wanted a little more stall. (331 ci motor though, but 3200# car). And cam was on 110 degree lobe centers, so power a little lower down.
3500 stall? Wow I wouiodnt think I would need that big. Again this is no strip truck. Just lighting the tires on the street when need to, and the occasional cruise
But if that is warranted then I guess I will look into those |
![]() Join Date: Aug 2014
I would think 2800 would be a good choice for that cam. Comp Cams recommends a 2500 minimal stall for there 230/236 cam I am going to be using in my truck.
Yea the more I read into it I'm thinking 2500? Increasing engine power has the same effect as decreasing vehicle weight. Since I'm coming from stock 882 heads, stock motor basically I would think it would average out to be in the mid 2000's 2500 or so.
Thoughts? |
If your truck is still stock weight expect that stall to operate in its upper range, and should be find for the combination you have.
