Old 01-03-2015, 08:52 PM   #1
slotard
Headlight mounting rings
I went to pull my headlights this morning to swap them for Jeep JK headlights, and on the side I touched the ring that holds the lens to the core support came apart. The tabs that appear to have been spot welded to the rings came off.
Item 2 on the round headlight here: http://www.lmctruck.com/icatalog/cc/full.aspx?Page=192
Are the LMC ones any good? Another option is to try to tack it back together, but blowing holes wouldn't be a big surprise (I have a mig, no tig here).
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-03-2015, 09:06 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: Headlight mounting rings
AutoZone has the rectangle ones. They might have the round ones.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 01-11-2015, 07:22 PM   #3
slotard
Turns out both of them have problems. I couldn't find any at my local Autozone. Any suggestions on which ones to buy?
Does anyone know if the earlier (67-72, or even before) retainers are the same?
1973 C20, 350/350
Old 01-11-2015, 07:41 PM   #4
whiskeydented
whiskeydented's Avatar
I broke a couple of tabs on mine too. I have a tig welder so I just fused them back on. Any chance you know anyone with a tig? I always hate buying that aftermarket stuff. Most times it's no better than the broken part you are replacing.
whiskeydented is offline   Reply With Quote
Old 01-11-2015, 08:01 PM   #5
slotard
Are they stainless rather than chromed mild? I do have a couple friends with TIGs, although the close one isn't so good at it (not that I am either). What did you do, autogenous or did you use some tiny filler rod?
1973 C20, 350/350
Old 01-11-2015, 08:39 PM   #6
Sabaka454
Sabaka454's Avatar
The LMC ones are good. I bought a set and am happy with them. Get the screws too.
Just search whatever local auto part stores you have for Dorman # 42408
Sabaka454 is offline   Reply With Quote
Old 01-11-2015, 08:53 PM   #7
slotard
Are the Dorman ones comparable to the LMC ones? If so I'll probably buy them locally rather than paying shipping.
1973 C20, 350/350
Old 01-11-2015, 10:24 PM   #8
whiskeydented
They're stainless. No filler needed, just zap it for a second. Haven't had a problem since I fixed mine.
Old 01-11-2015, 10:47 PM   #9
slotard
I'm thinking I might be able to get away with drilling a small hole and then tacking it with the MIG. If that doesn't work I'll likely buy some repros, it's cheaper than driving to my friend's place.
1973 C20, 350/350
