frame rivets
Can I put new rivets in the frame
1970 chevy short box c10 factory 402 big block with AC 2008 chevy silverado regular cab short bed lowered 1990 454ss 52,000 miles 5/6 drop |
![]() Join Date: Feb 2002
Re: frame rivets
If you have airtools: rivet hammer, bucking bar and a hot forge, then sure, why not?
Most of us replace them with Grade 8 nuts and bolts [not to forget washers and lockwashers, and double-nut 'em if there's room] and call it good.
![]() Join Date: May 2003
Re: frame rivets
Yes you can, I've done it, but it's not easy !
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
Re: frame rivets
Re: frame rivets
Do you think a frame shop would do it
Re: frame rivets
Certainly. It's your money. IMHO the Grade 8 bolts are better: you can tighten them up yourself in the boonies, if they work loose. If the hot rivets work loose, its back to the shop.
#7 | |
Re: frame rivets
Also - 3/8 bolts were used as a repair for missing/miss hit rivets on the assembly line.
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Re: frame rivets
Keith, was 3/8 the rivet size? They seem a little loose and the shank seems just a touch bigger. Looks like they were in between 3/8-7/16. I bought a box of 7/16 solid rivets for my crew cab build. Figured I would just drill up to the next size as the 3/8 rivets seem to "fall in." Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
Re: frame rivets
Correct me if I'm wrong, but the rivets expand inside too don't they? I was under the impression that they go in loose, and as the head is mushroomed that also expands the inside of the rivet which pulls everything into proper alignment. What I am trying to say is that as you mushroom the head, you are also squeezing the two rivet ends together which expands the center section of the rivet.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
All about them K’s
![]() Join Date: Jun 2014
Re: frame rivets
I can't speak for rivets but I can say that when I used to work in a couple different body shops once in a while we'd have a truck come in that had a spring hanger or something like that knocked off. We always used grade 8s for the repair.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#11 | |
SWB 4x4 Collector
Re: frame rivets
Re: frame rivets
OK. You have destroyed yet another assembly line illusion of mine. The truth shall set us free. My point was that the 3/8'' bolt was better than a rivet in the aftermarket.
#13 |
![]() Join Date: Jan 2012
Re: frame rivets
I have repaced the rivetsfor the frame stiffener on my 69 C/20 (trailing arm suspension) and they were 7/16 is .4375 the holes i put rivits in where about 27/64 = .422 so i got an 11 mm reamer ground to .431 and the 7/16 bolt fits great. It's a bit of a pain but worth it!
#14 | |
Re: frame rivets
![]() This is why-rivet missed the hole in the X-member: ![]() ![]() ![]() ![]()
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
#15 | ||
Re: frame rivets
![]() Just wanted to make sure I wasn't missing something... Quote:
K
#16 | |
Re: frame rivets
I'm not sure that rivet was ever bucked on right. A buddy welded the bracket back together, then I threaded the 7/16 bolts into the holes. It was a tight fit, but 40+ years of rattling around the Southwest deserts enlarged the hole somewhat. No need for the special tool J-5729 Reamer. Although I may have used the 1/2'' breaker bar. I sort of used the bolt threads for a tap. Threaded it thru, then backed it out again and assembled with washers and lockwashers. Fixed the bracket, new tires and I was back on the road. Before and After pix below: ![]()
#17 |
Re: frame rivets
I followed my truck down the line as it was being built. Since I knew I was going to be lowering my truck I asked the assemblers if they would use all bolts on my spring hangers.
They wouldn't do it. ![]()
#18 | |
Re: frame rivets
Unfortunately it looks like the frames are received already put together so I didn't see any loose parts down there. Seemed like a good idea at the time. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-06-2015 at 12:29 PM. |
#19 |
Re: frame rivets
I believe the original frame rivets were 11/32, very difficult to find, not sure if anyone even makes that size any long. So the next size up is 7/16, whether you use rivets or grade 8 bolts. If you go the rivet route there's a couple of rivet mfg.’s that have instructions on their web sites as how to install them.
They need to be cut to a certain length, metal thickness + a certain amount for peening. You also need the tools and an oxygen/acetylene torch. Bolts are much easier, but the rivets done right look factory. Gary PS: I bought a big box of rivets and have many left over.
