Old 01-03-2015, 11:25 PM   #1
drivea55
drivea55's Avatar
how to detect what year chassis you have?
Hey guys,
I am usually over at the 47-59 section cause my cab is a 50. I was told it is sitting on a 72 chassis.
I would like to buy drop spindles but am told that 71+72 are different cause the ball joints are different sizes.
I have 4 wheel drum on 6 lug axles, coil springs in the rear, no leaf.
What is the best way to determine the year?
I did notice some numbers stamped on the pass. outer frame rail. not sure if that will help any.
thanks in advance for any help in this matter.
Brian
current project;
1950 GMC "Junk Yard Dawg"
http://67-72chevytrucks.com/vboard/s...d.php?t=635960
___________________________________________
SOLD to "ONEBADFIVEFIVE"
http://67-72chevytrucks.com/vboard/s...d.php?t=436406
drivea55 is offline   Reply With Quote
Old 01-03-2015, 11:29 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: how to detect what year chassis you have?
A partial VIN may be stamped atop on the LH frame rail just posterior from where the steering box is attached. That # may also be helpful - post both if possible.
Old 01-03-2015, 11:31 PM   #3
BlueBullet
BlueBullet's Avatar
I am no expert but sounds like it would be a 67-70 frame if it is drums all around there also should be a Vin stamped in frame buy steering box on drivers side.
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 01-03-2015, 11:31 PM   #4
Maddoxdb
Maddoxdb's Avatar
I would say 63-70 being that you have 4 wheel drum and 6 lug hubs. 71-72 is 5 lug and disk brake front. Not sure how to tell exact year model but maybe somebody else will chime in.
Maddoxdb is offline   Reply With Quote
Old 01-03-2015, 11:32 PM   #5
Maddoxdb
Maddoxdb's Avatar
Must've been typing at same time^
Old 01-03-2015, 11:34 PM   #6
BlueBullet
BlueBullet's Avatar
Lol yea all three answered about the same time
1967 Pontiac GTO
Old 01-03-2015, 11:37 PM   #7
drivea55
drivea55's Avatar
thanks guys
I will try to get that number off the frame.
current project;
Old 01-04-2015, 12:13 AM   #8
michael bustamante
michael bustamante's Avatar
Also look to see if there is a dumple where a power steering box would cradle. If theres a dimple then its most likely a 68-70
No dimple most likely means 64-67
You have coil springs in the front right?
1967custom
michael bustamante is offline   Reply With Quote
Old 01-04-2015, 04:58 AM   #9
drivea55
drivea55's Avatar
Yes
coils in the front.
Not sure dimple?
Has manual steering box no power.
Sure is a lot a work to get to the bottom of this situation.
But I appreciate all the help!
Brian
current project;
Old 01-05-2015, 12:37 AM   #10
drivea55
drivea55's Avatar
Couldn't find anything near the steering box. The numbers on pass. Side are;
3935802-464
5. 7. -17
I also found 464 stamped on the frame in other areas.
Not sure if it helps but here is a pic of steering box.
Brian
current project;
Old 01-05-2015, 01:16 AM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
That part number is listed on this thread here for a 68 frame: http://67-72chevytrucks.com/vboard/s...d.php?t=270463
Some GMC frames do not have VINs stamped on them...
Old 01-05-2015, 07:14 PM   #12
drivea55
drivea55's Avatar
thanks!
I guess it's a 68 frame then.
current project;
