Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-03-2015, 11:57 PM   #1
Project86
nitrous on my 355
Wanting a bit more power from my sbc.
Right now it's just a .40 350. New internals but all stock.
Stock heads, springs etc.
Running a xe268 cam. Performer intake. Holley 650
Th350 trans with a 2000 stall
3.08 gears
Can't remember total timing off the top of my head but I'm wanting to put a littlle juice to it and have a little fun
Engine runs great. Good fuel pressure. No issues.
Want to get a single plane intake and eventually change over to electric fuel pump setup
as far as nitrous goes. What kit is best? Spray bar or a perimeter plate?
Wanting maybe 100/150 shot. Even less is fine.
Project86 is offline   Reply With Quote
Old 01-04-2015, 07:46 AM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: nitrous on my 355
Something along the lines of a NOS cheater or equall . Maybe even a fixed powershot . I mention the powershot as it would be less variable . You will need to know the exact timing and fuel pressure with nitrous .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 01-04-2015, 10:30 AM   #3
Project86
I can get exact timing when I get back home
as far as fuel pressure, right now I'm at a steady 6.5
Old 01-04-2015, 10:41 AM   #4
Project86
Did a quick search. So the PowerShot is a dedicated size.
Since I'm running a single fuel feed. Would I get that T fitting run a line to the fuel solenoid. And one back to the carb
Old 01-04-2015, 11:13 AM   #5
hotrod 80
mini truck racer
hotrod 80's Avatar
Yes , if you dont have a dedicated fuel system for the nitrous , then you will need to split off the carb fuel pump . This pump needs to be up to the task of both the carb and the plate and able to maintain fuel pressure with both drawing on it . Any drop in fuel pressure will effect the "tune up" on the the plate .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 01-04-2015, 01:11 PM   #6
Project86
I had a Holley 80gph mechanical on the motor for a little over a year but the pump diaphragm went out. Right now it has just a stock replacement. Which I think may be 60gph. Not too sure. But electric is soon in the works.
Old 01-04-2015, 03:59 PM   #7
cableguy0
Honestly you would probably see better all around performance from changing the gears. A 3.73 would do wonders over the 3.08. I assume your not terribly concerned with gas mileage. Obviously a 100shot or so will work wonders too but its only there once in a while and keeping that bottle full can get spendy over time.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 01-04-2015, 04:38 PM   #8
Project86
Funny thing you mention gears. I have a brand new set of 3.73s I'm waiting to put in.
I'm more or less confused how to run all the hardware.
I'm looking at a fuelcell with a sump. 2 an fittings and a vent. I want to use a single fuel line but somehow run it to the carb and to the fuel solenoid. All without having a huge mess.
Can I run a fuel log from the carb. Connected to a regulator before the carb where my fuel enters. And from there add another regulator and tap into the fuel solenoid?
Old 01-04-2015, 05:17 PM   #9
hotrod 80
mini truck racer
hotrod 80's Avatar
I agree gears and more converter would be my first move .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 01-04-2015, 05:21 PM   #10
Project86
3000 stall?
Old 01-04-2015, 05:36 PM   #11
HemiChallenger71
HemiChallenger71's Avatar
You dont necessarily have to switch over to a single plane to spray an engine. I'd look into a zex perimiter plate myself. I've had good luck with zex stuff on daily driven vehicles. Very high quality.
Also for a 100-150 shot keeping the tight converter and highway gear could get interesting. The complicated part comes from the shock load on the rotating assembly on gear shifts dropping RPMs. When nitrous engines are being sprayed and at lower RPMs your still adding the air for that 150 extra ft. lbs. so its actually more ft. lbs. If it were my engine/trans combo I'd keep everything the way it is and see what happens on a 100 shot.
Also a 10 lbs. bottle will last a while with only a 100 shot. Like safely 8-10 passes if you get a good bottle fill and use a warmer.
HemiChallenger71 is offline   Reply With Quote
Old 01-04-2015, 05:45 PM   #12
Project86
Can you give me advice on how to run everything from the tank to the carb. I saw a setup where guy had fuel feed line running to a regulator at the end of a fuel log. Then fuel solenoid at the end of the fuel log
I want to keep it clean and simple.
And still be able to run a return line back to the sump of the fuel cell I plan on putting in.
Old 01-04-2015, 05:59 PM   #13
HemiChallenger71
Your going to use one pump for engine and nitrous?
You need to have two separate regulators, 1 for engine and 1 for nitrous. You need to feed both. If you use the engine regulator as the return you can use a non-return to feed the n20. The n20 regulator will need to be set flowing fuel with the engine running.
Also how big of a cell? Gonna have to watch the fuel level with the return style system.
Return style systems create more problems than they solve IMOP at power levels this low.
Old 01-04-2015, 06:13 PM   #14
Project86
Fuel cell is a 16 gal. Two -8AN pickup fittings and one -8AN vent. I'd be fine with no return. As my truck runs with no return as well right now. So could I possibly have a regulator before and after the fuel log? And run the fuel solenoid off the regulator to the perimeter plate?
Old 01-04-2015, 06:22 PM   #15
HemiChallenger71
So you havent purchased the pump yet?
I'd run a single feed and y-it to two regulators or run the log with two regulators off it. You cant run one after the other with a non-return system.
Old 01-04-2015, 06:26 PM   #16
Project86
No pump has been purchased yet. Getting a better idea of parts before it's set in stone. How exactly can I run the log with the two regulators off it?
Old 01-04-2015, 06:34 PM   #17
HemiChallenger71
Going to have to get a log with at least 3 ports. Regardless you have to have 2 regulators any way you cut it and the pump needs to feed both directly in a non return style system.
Old 01-04-2015, 06:49 PM   #18
Project86
Ah ok. So what your saying is I need the regulators to be separate from the fuel log itself since you said I can't run them right after one another. Correct? A diagram would come in handy right now haha.
Old 01-04-2015, 06:55 PM   #19
Project86
So would jegs part #555-15931k be perfect for what were trying to achieve.
Old 01-04-2015, 06:58 PM   #20
HemiChallenger71
Yes!
Its hard to convey via text. I'm not the greatest linguist either.
1 line t's or y's into two separate regulators. 1 feeds the carb, 1 feeds the n2o solenoid.
Old 01-04-2015, 09:59 PM   #21
Project86
Yes!
Haha. Went into jegs app and typed in regulator. First one that popped up.
Old 01-05-2015, 10:46 AM   #22
Marv D
Registered Truck Offender
Marv D's Avatar
For a visual and writeup of the sound advice you have been getting, ...
http://www.centuryperformance.com/fu...endencies.html
Read the ENTIRE article. Sam has a lot of overkill built in to his thoughts, but OVERKILL doesn't hurt parts. N2O is a cutting torch looking for the chance to melt internal engine parts. Screw up just a bit and...
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
