01-04-2015, 07:04 PM | #1 |
disc brakes
my 1957 truck has a front clip from a 1968 c10. 6 lugs. it has the original drums. i got a new MC and prop valve and new lines are in. new drums in the rear. im ready to upgrade the front to disc brakes.
should i buy a "kit" off the internet with everything i need for around $550.00, or is there a more cost effective way to get this done. no junkyard parts, i want to install new parts.
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
01-04-2015, 08:06 PM | #2 |
Re: disc brakes
personally, for the older trucks (pre-67), I like the kits. For 67-70, I like to use the 71/72 front and then just use stock parts.
01-04-2015, 08:11 PM | #3 |
Re: disc brakes
What is the 71/2 sub? 71 suburban? 71 subframe?
01-04-2015, 09:16 PM | #4 |
Re: disc brakes
for my 67 I got the kit from CPP. Everything to do the switch was included and fit perfect.
01-04-2015, 09:33 PM | #5 |
Re: disc brakes
1968 Chevy C20 |
01-04-2015, 10:27 PM | #6 |
Re: disc brakes
^^ thank you that is very useful . So if I wanted to save some $$, I can try to find stock spindles from a 1972 c10 at the salvage yard and then use stock '72 parts to install the new brakes including '72 ball joints and tie rod ends (which I will replace either way)
