Need help with EFI fuel line
I am installing a Boyd Welding EFI fuel tank and an LT1 motor in my 71 C10 shortbed. What are you guys doing for fuel lines? I'd like to install an inline filter on the inside of the frame rail. Not sure what kind of those to get either.
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
Re: Need help with EFI fuel line
Well, I'm figuring it out. I've got a shopping cart with a bunch of Russell hoses, but I'm stuck on how I join them to the fuel rail. here is a picture of my fuel rail. It looks like there is a fitting that will convert this to -6AN?
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. Last edited by FL71C10; 01-05-2015 at 12:04 AM. |
![]() Join Date: Nov 2014
You might check the "conversions" section on LS1Tech.com. I used a couple quick connect ends like in your pic to install a Corvette fuel filter/pressure regulator before my Walbro in line pump(low pressure/prepump). Then I used push lock connectors and versaflares to connect hard lines to push lock line. Hope this helps.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
Thanks, I'll check out that site. I got the tool to get the old fuel lines off the rail.
What's a versaflare?
Cut those fittings off and order these for the different sizes (3/8 & 5/16),
http://www.summitracing.com/parts/sum-2200077b
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
Thanks for the suggestion. I called Jegs and got a lot of help and prices. The Boyds tank comes with an Aeromotive pump that is apparently a very nice one. The guy at Jegs told me I should get a better filter than I was looking at but the filter alone is $110 with brackets and fittings.
I'm going to call Summit tomorrow.
You may can use the hoses from a later truck or car. I did a TPI conversion on a '72 SWB and used the fuel tank and complete lines from a S10 Blazer. I had to do 2 splices (used hydraulic unions, not low pressure ones) but I had steel line, not the later plastic. Look for '93-96 Caprice/Roadmaster. They had LT1 and fuel tank at the back.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
![]() Join Date: May 2013
Yes
russell 644120 and 644110
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
Keepin an eye out
Subscribed - Have the same tank sitting in my livingroom/
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
I have ordered the JEG's version of those and should have them tomorrow. I think I am going with braided hoses, just for ease of installation. it's more expensive, but not that much more.
Mine is only one step further along, clamped onto the frame rails. I'll bolt it in this weekend.
#12 | |
#13 |
True, but they are not affected by ethanol fuel. Evil stuff, but a fact of life these days.
#14 |
Actually the nylon lines are awesome. You can but a roll of it at O'reilly's parts and use push on barb fittings. If you are worried about rubbing/chafing you can put it inside a larger diameter hose you just do like I do and clamp it about every 16" or so. I get the barb on one end fitting and threads on the other end from ACE for a couple bucks. Have used this "Dorman" product line hose on a couple and never had any problems or leaks. easy to route and tuck up inside the frame rails.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
#15 |
I'll check into it.
Thanks!
#16 |
OK, making some progress. I got the old fittings off with the disconnect tool, and got Russell screw on fittings (they seem to work better than the Jeg's snap on ones. Here are the new fittings installed waiting for fuel lines. I'm going with braided steel fuel lines with -6 AN fittings.
#17 |
I got the tank in. Here it is, and here is the 90 degree 3/8 NPT fitting to -6AN for the fuel hoses. That's just a cheapie rubber hose on there so I can see the bend that the line will have and it will help me determine the right length for the fuel hoses.
#18 |
Here's the fuel filter installed, waiting for fuel hoses.
#19 |
![]() Join Date: Dec 2014
#20 |
Thanks. It seemed like the best choice and wasn't stupid expensive. (I guess that depends on your perspective)
