Steering column installation help!
Hey guys I removed my column 3 years ago and now it's time to reinstall. I've tried to find a specific pic or instruction and can't seem to find it. I hope one of you guys can help out.
On top of the column there are 3 notches or slats that fit into a "tooth" if you will. Which one of the 3 "notches" does that "tooth" go into? The one closest to the wheel or the one closest to the firewall? Any help is greatly appreciated. 1968 GMC BBC truck. Just invade that makes any diff.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
Re: Steering column installation help!
Where exactly are you talking about? I recently installed mine. Automatic column?
Thanks, Casey ![]() The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
The Older Generation
I don't remember a column with three square notches in it. If I had to guess I would say the one closest to the wheel. If it wasn't -1º out I would go out and check a couple of my columns... ![]() LockDoc
TILT COLUMN GURU
![]() Join Date: Dec 2006
The one closest to the firewall.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
There you go.... I would be wrong.... Kev is the "Go to guy" for tilt columns, he has rebuilt a LOT of them. LockDoc
![]() So the one furthest down the column right? These are the "notches" I'm talking about. Thanks again for your help guys.
Hey guys. Im new on here and not able to make a new thread. I'm having trouble with my 1968 column also. Mine is non tilt and I can't get the bearing/turn signal housing to sit on the column correctly. There are 3 "tack welds" that im assuming are supposed to act as keepers to keep it from turning with the wheel. But for whatever reason it wont go on straight. If anyone can help please message me. Thanks!
#8 | |
![]() Join Date: Feb 2001
Your should be able to start a new thread. Just hit the new thread botton. By the way: ![]() ![]() ![]()
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Thanks! But where is the new thread button? Lol
