Old 01-05-2015, 04:18 PM   #1
Apachemike
Apachemike's Avatar
Steering Column (58-59) Question of the day
Hopefully this is a simple question. Can I remove my stock column from my 59 and cut 2-3" out of the inner shaft to shorten the length? I'd like the column closer to the dash. I can have it welded back or grind it to install a D-D adapter. I just haven't figured out what to do for the outer cover
Apachemike is offline   Reply With Quote
Old 01-05-2015, 04:19 PM   #2
Apachemike
Apachemike's Avatar
Re: Steering Column (58-59) Question of the day
Oh, 59 3100
Old 01-05-2015, 04:56 PM   #3
OrrieG
OrrieG's Avatar
Assuming you are not using the stock steering box, but want to retain the original column, go to CPP and look at the "column saver" kit. It was made for doing just that. You cut the column to length, insert a bearing, then cut the shaft to length. You can grind for a DD fitting or use a pinned round one.
OrrieG is offline   Reply With Quote
Old 01-06-2015, 12:54 PM   #4
Apachemike
Apachemike's Avatar
Everything is stock
Old 01-06-2015, 03:30 PM   #5
mr48chev
mr48chev's Avatar
I'd think that what you plan with grinding the ends of the shaft and using a double D connector would be the safe way to go and keep it appearing stock.
Just make sure that the shaft and the inside of the DD piece are the same diameter (round part of DD) before grinding the flats. I'd drill and pin it after I had it together. That would be a whole lot safer than cutting it off and welding it back together which isn't legal in some areas of the world.
My ongoing truck projects:
Old 01-07-2015, 10:17 AM   #6
Russell Ashley
Russell Ashley's Avatar
I think you will need to remove the steering box and column from the truck to do what you want to do. The shaft doesn't stick out far enough on top to cut and the column jacket doesn't come out of the steering box. I think if I were doing it I would cut the column jacket and remove it. Then cut the shaft and remove the amount that you want to shorten it, and use DD or what ever method you choose to connect it back together. Then cut the exact same amount out of the column jacket, put it back on the shaft, and weld it back together. If you have a column shift you would have to shorten the shift rod the same amount as the column. I think the most time consuming thing will be removing and installing the steering box.
Russell Ashley is offline   Reply With Quote
