01-05-2015, 07:13 PM | #1 |
Speedometer/trans compatibility question
I have a '65 c10 with the stock speedometer and, I'm installing a TH400 trans. Will the speedo work correctly with the TH400?
01-05-2015, 07:56 PM | #2 |
Re: Speedometer/trans compatibility question
It should work ok. You might have to change the plastic drive gear in the transmission to make the speedometer accurate.
01-05-2015, 09:36 PM | #3 |
"It should work ok. You might have to change the plastic drive gear in the transmission to make the speedometer accurate"
Thanks for the reply. What's involved with that and, where do I get the correct gear? |
01-05-2015, 10:15 PM | #4 |
First you should know how many miles per hours the speedometer is off. Then you need to know how many teeth are on the current gear (also color). On my truck, reduction of 2 teeth changed the speedometer by 5 mph.
01-05-2015, 10:40 PM | #5 |
Remove speedometer drive from the tailshaft housing. Colored plastic gear slides out. Your local transmission shop should have gears
01-05-2015, 10:52 PM | #6 |
Thanks Guys, appreciate it!
01-06-2015, 01:39 PM | #7 |
should be the same as it's been with the old trans if not an overdrive you are removing. that is if it was right to begin with.
1961 chevy K10 my build is------------61K10 build |
