![]() Join Date: Feb 2000
C-20 Frame Swap
Guys & Gals,
I 'm buying a C-20 frame with front disks to put under my 68 C-20. The new frame has everything from the Stering box to the wheels and a leaf spring rear. My 68 has frt drums and Coil rear. Besides the Front brake changes I need to make. What is the best way to go about moving the eng/trans & body (fenders/cab/bed)? What all needs to be unhooked? Does Is there a special order to follow or any helpful hints that you all can help me with? |
Resident Curmudgeon
![]() Join Date: Dec 1999
Your driveshaft will need to be changed. The coil vs leaf drivshafts are different
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
I wondered about that, but didin't remember ever reading it. Thanks for the tip CPNE, I'll see if i can get one with the frame.
