Old 01-06-2015, 01:50 AM   #1
Goose
Goose
Goose's Avatar
More gas tank revisitied
So far the two options on '67-'72 gas tanks is to live with it or move it. I choose to live with it and have for 39 years. But, I would like to hear a discussion from some folks using the stock installation who have figured out how not to spill gas in right hand turns, ruin paint jobs, and create the gas fume issue. Of course the quick answer is don't fill the tank up, but has anyone tried installing any baffling, better seals, designed or found a better cap, ....or something? Thanks.
'72 GMC short-step 350/350
Goose is offline   Reply With Quote
Old 01-06-2015, 02:44 AM   #2
leftybass209
leftybass209's Avatar
Re: More gas tank revisitied
A quality gas cap and seal on the sender yields no gas smell and no leaks. If it's an ecc tank replace the vent hose as well. I have seen people cut and use thicker rubber on gas caps. Thickness is usually trial and error depending on gas cap and what you currently have.
leftybass209 is offline   Reply With Quote
Old 01-06-2015, 10:25 AM   #3
Katrina/10
Katrina/10's Avatar
Stock non-vented gas cap on a 71, no leaks when turning.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 01-06-2015, 10:27 AM   #4
Lee H
Lee H's Avatar
Have to agree with lefty, if all the rubber hoses, sender o-ring, and gas cap seal are fresh there will be no fumes in the cab and no cap leakage on turns. I have seen instances where the neck is worn to the point that the cap would not tighten down and or continued to spin.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 01-07-2015, 10:17 PM   #5
slow-1
slow-1's Avatar
I too have no fumes and no spills. I used to have fumes before I replaced the fuel tank with holes rusted through the top.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 01-07-2015, 10:28 PM   #6
70STOVEBOLT
70STOVEBOLT's Avatar
That is what I did. Cut my own gasket from 1/8" thick rubber and I have not had any gas smell or spillage since. And I fill up every week.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-07-2015, 10:35 PM   #7
twouvakind
twouvakind's Avatar
Agreed, many a trip to the pump over 40 some odd years yields a distorted filler neck. I trashed my old EEC(tank)and went for a non EEC and a Stant locking gas cap. Rock Auto carries Spectrum, good Canadian manufacturer. Best under $200 you will spend and cease the fumes.
If you want to go budget, go with some of this stuff for a gasket:
Viton is a brand of synthetic rubber and fluoropolymer elastomer commonly used in O-rings and other molded or extruded goods. The name is a registered trademark of DuPont Performance Elastomers L.L.C.
twouvakind is offline   Reply With Quote
Old 01-08-2015, 12:53 AM   #8
Goose
Goose
Goose's Avatar
All great ideas. Thanks for the responses. Trucks at the paint shop now, but will get a new cap and add some seals.
