Old 01-06-2015, 10:39 AM   #1
Unionwelder
Unionwelder's Avatar
Grille repair and paint
Hey yall,
I'm repairing the snaggle toothed grille on my 72. My question is what paint should I use over the chrome surround? I'm going to use a rattle can for now but am not sure about the paint adhering to the chrome.
-Sterling
GIG EM' AGGIES!!!! WHOOOOOOP!!!!!
"Whether you think you can or think you can't, you're
Right." -Henry Ford
1972 chevy lwb
1934 ford p/u
Unionwelder is offline   Reply With Quote
Old 01-06-2015, 01:26 PM   #2
JAC10K
JAC10K's Avatar
Re: Grille repair and paint
Just rough the hell out of it to ensure adhesion, but also use a good etching primer and then filler primer.
_____________________
'72 C10 Custom Fleetside
JAC10K is offline   Reply With Quote
Old 01-06-2015, 02:00 PM   #3
R.L.
R.L.'s Avatar
I did the exact same thing after bondoing a spot I wasn't satisfied with. I plan on replacing it later. Duplicolor is what I used. Put it on thick then rub it down with rubbing compound. Mines been on a couple years now. Unless your sitting next to a shiny new aluminum one, no body seems to notice. I'm out of Mobile what local you out of.
R.L. is offline   Reply With Quote
Old 01-06-2015, 02:28 PM   #4
Unionwelder
Thanks yall, I've never had luck getting paint to stick to polished surfaces. I'm out of Austin UA local 286.
-Sterling
Right." -Henry Ford
1972 chevy lwb
1934 ford p/u
Old 01-06-2015, 05:55 PM   #5
R.L.
R.L.'s Avatar
I didn't expect this to stick but tried anyway, when I said I put it on thick that's what I did. I used the whole can or most of it, probably 3/32 to 1/8 thick. It's hard and hasn't even thought about coming off.
