Old 01-06-2015, 11:15 AM   #1
inkslinger1964
shift linkage bushing
1964 chevy c10, 283 3 speed colum shift. shifter is very sloppy with lots of play.
grommets or bushings at lower end of linkage is worn colmpletely out where it connects to shift control arms. Where can i purchase new bushings.
inkslinger1964 is offline   Reply With Quote
Old 01-06-2015, 12:39 PM   #2
pimpston65
pimpston65's Avatar
Re: shift linkage bushing
Originally Posted by inkslinger1964 View Post
1964 chevy c10, 283 3 speed colum shift. Shifter is very sloppy with lots of play.
Grommets or bushings at lower end of linkage is worn colmpletely out where it connects to shift control arms. Where can i purchase new bushings.
lmc
pimpston65 is offline   Reply With Quote
Old 01-06-2015, 12:41 PM   #3
pimpston65
pimpston65's Avatar
Can you show more pics of the trans I'm trying to match a 3 speed I just picked up to see if mine is correct
Old 01-06-2015, 12:50 PM   #4
inkslinger1964
i dont have any additional pics of trans at the moment but i can take some.
Old 01-06-2015, 01:11 PM   #5
65 C20
You can check this out for adjustments.
Parts also availiable from Classic parts
http://67-72chevytrucks.com/vboard/s...d.php?t=215307
65 C20 is offline   Reply With Quote
Old 01-06-2015, 01:32 PM   #6
theastronaut
theastronaut's Avatar
I used oil impregnated bronze bushings from the hardware store. Measure the ID and OD and you should be able to find something that matches at Ace or Lowes. Better shifter feel too since they're solid.
theastronaut is offline   Reply With Quote
Old 01-06-2015, 03:25 PM   #7
frankslagoon
Originally Posted by pimpston65 View Post
lmc
I looked thru the cat. and can't find a kit but I think someone makes em. those thing can be a real nightmare. I love crawlen under the trk in a puddle to pull the shifter back into neutral. here is a pic of the tranny from my 63.
frankslagoon is offline   Reply With Quote
Old 01-06-2015, 03:56 PM   #8
pimpston65
pimpston65's Avatar
Thks for the pic, I like the brass sleeve idea, I will try that with my 3speed build...
Old 01-06-2015, 04:00 PM   #9
pimpston65
pimpston65's Avatar
Did you use a washer on each side of the bronze sleeve? The ones I just knocked out while removing the rods were metal and rusted to heck, not plastic maybe originals...
Old 01-06-2015, 04:14 PM   #10
padresag
you can get small bronze bushings with a face on one side.
ron
padresag is offline   Reply With Quote
Old 01-06-2015, 06:01 PM   #11
theastronaut
They looked like this, flange on one side.
Old 01-06-2015, 07:16 PM   #12
pimpston65
pimpston65's Avatar
nice, i got a local hardware store has a ton of em cheap less then $1 a piece!!!
Old 01-06-2015, 08:21 PM   #13
padresag
door hinge pin bushings
ron
