01-06-2015, 01:20 PM | #1 |
C10 Collector
Changing Window regulators
My buddy gave me two window regs and I need to put them in my 67. How far do I have to take the door down to change them? I laos need to change the latch on one door while I'm in there. Am I looking at a 2 hour job or 8??? Its been 11 yrs since I was in one of these doors and I've forgotten.
///Ryan 1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors 1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10 1967 Chevy LWB- 454 and patina 1971 Blazer - Rusty 1968 Crewcab project |
01-06-2015, 02:11 PM | #2 |
Re: Changing Window regulators
if i'm not mistaken, the vent window needs to come out in order to change the regulator. I always HATE dealing with the vent window removal. I think your safe with a 2 hour or less guesstimate.
01-06-2015, 02:22 PM | #3 |
2 hours start to finish sounds in the ball park for the first time. You can probably cut that down to an hour if you really grasp what you're doing for the second one. The wing window for sure has to come out, and I think i did one side with the door handle mechanism in, and one side with it out, and it was a pain with the one staying in. They aren't that hard to replace when you get everything aligned right, it's just tricky because you can't see everything easily. Best of luck!
01-07-2015, 09:54 AM | #4 |
I had the best luck loosening the vent window and having a second person just hold it up and out of the way. Once you get the window back on the track try and get the vent window and door glass postioned at the same time. I think if you search it someone wrote up a nice article on doing this on the forum.
Thanks, Casey 71 Chevy C-10 SWB 350/400 PS, PB The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
