Old 01-06-2015, 02:51 PM   #1
etrone76
SSR frame swap?
Has anyone done a Chevy SSR frame frame swap on a 47-53 pickup? I see they have the same 116" wheel base and are similar on width dimensions (outside tire to outside tire). I see them time to time for sale as a complete chasis with LS engine. Seems like an interesting build to gain modern drivetrain and power, if thats your goal.
etrone76 is offline   Reply With Quote
Old 01-06-2015, 03:21 PM   #2
mr48chev
mr48chev's Avatar
Re: SSR frame swap?
Had to do my homework on that one. It should work pretty nice as that is the same basic chassis as a Trailblazer or Bravada.
Unless you find one with serious body damage I'd think the cost of the donor rig would be pretty high as those go for serious money around this area. Not many around and the demand for them by the country club set is high.
The cheapest used one I found on Craigslist in the Pacific Northwest is listed at 14291.00 http://seattle.craigslist.org/est/ctd/4794776385.html Not something you just run down to the used car lot and pick up and drive home and pull the body off to do a swap unless you belong to the more money than good sense club.
My ongoing truck projects:
Old 01-06-2015, 04:06 PM   #3
etrone76
Re: SSR frame swap?
Thanks for the feedback, I have seen a couple of the SST chasis for sale on ebay and an LS forum. Complete chasis, no body. Engine, trans, wiring, computer, suspension, brakes, fuel system, wheels/tires, etc for 7-8k. Seems like it would be a good buy since you can spend close to that for just a 6.0LS and transmission.
Old 01-06-2015, 06:44 PM   #4
mgchevyparts
mgchevyparts's Avatar
Re: SSR frame swap?
2005/06 are the 390hp LS2, 03/04 are just the 5.3 truck engine. In my opinion the LS2 is the way to go if you can find a low cost donor.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 01-06-2015, 06:51 PM   #5
etrone76
Re: SSR frame swap?
The one I found is an '06 with 6.2 and 4L65E transmission with 71k miles.
Old 01-06-2015, 07:07 PM   #6
mgchevyparts
Re: SSR frame swap?
I would suspect they are hard to find without a body. 71K isn't that low but isn't bad. If this chassis fits well then it's a good deal with the horsepower, good trans, good rear end, four wheel disc brakes. I had an 05 , alum dual piston calipers 12.8" rotors all around etc.
Old 01-06-2015, 07:14 PM   #7
mgchevyparts
Re: SSR frame swap?
The SSR is heavy, over 5000lbs stock. Runs 13.9 all day. I would suspect you would be around 1000lbs lighter, should make for an interesting grocery getter
Old 01-06-2015, 08:03 PM   #8
mr48chev
mr48chev's Avatar
Re: SSR frame swap?
I'd think that that chassis with an AD body on it finished with a tank of gasAm
The first one sold in this area was a purple one that belonged to a Native American lady who was in her 70's or 80's and had a rack on the back for her power wheelchair. That one evidently left the area after she passed away as I haven't seen it for at least five years.
