01-06-2015, 04:35 PM | #1 |
Strange plastic(?) shavings in fuel filter
Hey guys, I had some problems with my engine and decided to pull it. After taking off the fuel line and checking the filter, i noticed these weird shavings inside the filter. They aren't magnetic..so at least they aren't steel, but they look like plastic. Anyone have any clue where the hell this could have come from? I haven't had a chance yet to take a look at the carb to see if they're in there.
Chris Mead Tattoos |
01-06-2015, 04:37 PM | #2 |
Re: Strange plastic(?) shavings in fuel filter
Might be a hose somewhere in the system that isn't fuel rated. It usually crumbles from the inside sending little black particles towards the carb.
"Life is too short to drive a boring vehicle". Later, Wayne |
01-06-2015, 04:42 PM | #3 |
hrmm..well there's only one small hose that goes from the tank to the metal fuel line. I'll be sure to check it for damage and the metal line for blockage. You think there might be any of that crap in the tank as well?
01-06-2015, 05:55 PM | #4 |
Could be anything. Time to pull and flush the tank, lines ect.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
01-06-2015, 06:03 PM | #5 |
Deteriorated strainer sock. Keep changing the filter for a while.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
01-06-2015, 07:16 PM | #6 |
x2 on this. also might be a deteriorating fuel line as well
1967custom |
01-06-2015, 07:26 PM | #7 |
Moderator
x3. Rubber not rated for fuel gets gummed up and turns to slime. The sock looks like this when it's shot.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
01-06-2015, 07:30 PM | #8 |
01-06-2015, 07:50 PM | #9 |
I believe that is the disintegrating plastic fish net strainer that is suppose to be at the end of the pickup tube in the gas tank to keep the bigger particles from being sucked up into the gas line. They tend to disintegrate after 40 years or so. Pull the pickup tube and see if there is anything at the end of it except a metal washer that use to have the "sock" on it. It should look like this: http://www.classicindustries.com/pro...arts/k405.html
01-06-2015, 08:20 PM | #10 |
Damn good thing you had a filter in line...
1953 Chevy 3100 1964 Chevy Impala 1966 Chevy El Camino 1970 Chevy C10 Fleet Long 1972 Chevy C10 Step long 1985 Chevy K10 Fleet Short |
