on my 67 k10 i have a 205 transfercase in it, and it is leaking the fluid out of the speedocable where it looks to be a grease fitting? is there a seal that is bad or what can i do to have this not happen thanks
matt
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
![]() ![]() Join Date: Jul 2002
Mine does it too...There is a O-ring around a bullet looking do hickey(I dunno what it is really called) that slides into the tranny. I need to replace mine also. Just disconnect thed speedo cable , remove the bolt & tab next to it and the bullet thing will slide out and you'll see it.
Cantankerous Geezer
If the fluid is in the cable housing, it's the internal seal around the speedo gear. Also check the speedo gear shaft for wear.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Transmission fluid can leak into the transfer case which raises the level and causes more fluid to run out. It might be worth while checking the fluid in the transfer case by removing the UPPER
plug and letting any excess drain off, (if any). Jim |
thats how ive been checking the fluid level, its just down because its leaking threw the cable but thanks anyways.. when it gets light out im gonna take a check on the cable and wear on it.
matt
